Home > Forums > Software User Forums > SU2
low mach number flow in su2
Old   August 24, 2020, 16:09
Default low mach number flow in su2
punyaplaban is on a distinguished road
Hi there,
I was just trying to simulate my own wing joined to a cylindrical fuselage in SU2. For the transonic regime, JST gave pretty good results. However, when I try to simulate at low mach numbers (incompressible regime), the solution does not converge. I am using ROE scheme with MUSCL_FLOW = YES. Any suggestions about running the test case at low mach numbers? Can anyone explain how to impose artificial compressibility in SU2 for these low mach numbers and how to impose low mach number preconditioning?
Thanks in advance!
punyaplaban is offline   Reply With Quote
Old   August 25, 2020, 05:25
Akshay Koodly
akoodlyr is on a distinguished road
You will have to use the incompressible solver. You can find examples and tutorials to set up here https://su2code.github.io/tutorials/...lent_NACA0012/ for example.
Cheers
akoodlyr is offline   Reply With Quote
Old   August 25, 2020, 11:49
Amit
aero_amit is on a distinguished road
You can also try low Mach schemes like AUSMPLUSUP and SLAU. These schemes do well for Mach 0.01 or even lower (proper scaling of numerical dissipation). But without Time derivative preconditioning, I recommend you to use them upto Mach 0.1 and also add option USE_ACCURATE_FLUX_JACOBIANS = YES with above schemes (AUSMPLUSUP/UP2 or SLAU/SLAU2).
aero_amit is offline   Reply With Quote
Old   September 10, 2020, 14:43
Thanks for the reply @aero.amit. I have tried LOW_MACH_CORR = YES and MUSCL_FLOW = YES options but that did not help. Does only USE_ACCURATE_FLUX_JACOBIANS = YES suffice for low mach case with the schemes you have suggested?
Old   September 10, 2020, 14:45
Thanks for the reply @akoodlyr. I have tried that but that did not help. Any other suggestions would be great.
Old   September 12, 2020, 08:50
Amit
Did you try AUSMPLUSUP scheme instead of JST?
Old   September 12, 2020, 15:29
No, I have not tried that. Are you saying to try AUSMPLUSUP with USE_ACCURATE_FLUX_JACOBIANS = YES setting? Should I turn the MUSCL_FLOW = YES also for a second order scheme?
Old   September 12, 2020, 16:02
Amit
Yes, try the above settings
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 11:27
Turbulent flow at low Mach number robyTKD SU2 5 January 3, 2014 04:18
