Home > Forums > Software User Forums > SU2
Runge-Kutta Memory Error
Old   June 24, 2020, 13:38
Default Runge-Kutta Memory Error
BrianB is on a distinguished road
I am trying to run an unsteady simulation with 2nd order dual time stepping in SU2 v6.2. When using the Euler implicit scheme for TIME_DISCRE_FLOW, the solution produces non-physical results but continues to run. When I try running with the Runge Kutta explicit scheme (or the Euler explicit scheme) the solution will run for approximately 1100 external iterations before exiting with a BAD TERMINATION error with exit code 11, which seems to point to a segmentation fault. Is there a way to fix this? Why would the implicit scheme continue to run but the explicit scheme crashes? Before it exits, the restart files produced by the explicit scheme seem to be plausible.
BrianB is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
