Home > Forums > Software User Forums > SU2
NASA CRM wing simulation in SU2
Old   June 23, 2020, 20:39
Default NASA CRM wing simulation in SU2
Ranjan
Ranjan is on a distinguished road
Hello
I am trying to simulate inviscid flow-field around the NASA CRM wing. Even though my dimensions are correct, I get extremely high values for CL and CD ( almost double ) when compared to the design conditions of AOA ~ 2.34 degrees.
I have tried both manual and automatic values for A_ref ( by setting A_ref zero), the manual entry for A_ref being 191.82 m^2.
I have also tried multiple mesh resolutions, varying from 3-9 Million.
Any suggestions ?
Thanks in advance
Ranjan is offline   Reply With Quote
Old   June 23, 2020, 22:33
hpatel is on a distinguished road
Originally Posted by Ranjan View Post
Hello
Any suggestions ?
Thanks in advance
What is the x-y-z orientation of your mesh? In relation to that, why is the AOA=0 in the config file?
hpatel is offline   Reply With Quote
Old   June 23, 2020, 23:07
Ranjan
I am not sure what you mean by " why is the AOA in the config file ? "
The flow angle of attack is always defined in the config file. The config file is attached as a .txt file with my post.
Thank you
Old   August 24, 2020, 16:13
punyaplaban is on a distinguished road
What is the axis of lift in your mesh? Is it z-axis?
punyaplaban is offline   Reply With Quote
Old   September 3, 2020, 15:58
Default Resolved
Ranjan
I figured out the problem. The axis orientation and the configuration in general were correct. However, Euler flow assumption especially for the CRM wing at design condition leads to spurious ( over-predicted ) aerodynamic characteristics. While one might expect to predict the pressure forces and hence the lift distribution to a reasonable accuracy, the CRM geometry encapsulated viscous effects such as shock-induced boundary layer separation , a phenomenon absent in Euler assumption.
Upon switching to RANS and a computational domain with appropriate near-wall resolution ( yPlus ~ 1 ), the flow characteristics computed were reasonable when compared to other numerical experiments.
Thank you all !
crm wing, euler, su2
SU2 propeller simulation helpmewithcfd SU2 2 October 19, 2020 06:08
Material definition- nasa polymonials oliveira1820 CFX 2 May 22, 2019 09:29
[ICEM] HEX Structured mesh around NASA CMR wing raz ANSYS Meshing & Geometry 1 October 22, 2016 14:21
[DesignModeler] Gap seen in NASA CRM models in designmodeler, not visible on CATIA mayin12 ANSYS Meshing & Geometry 1 June 15, 2016 17:25
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
