June 23, 2020, 15:52 |
TIME_STEPPING unsteady simulation
Rep Power: 6 |
I am trying to run an unsteady simulation using the TIME_STEPPING method. I have implemented a forcing term in SU2 v6.2 that turns on after a certain number of external iterations, this approach has worked for dual time stepping. However, when I tried running the same simulation but with the unsteady mode switched to TIME_STEPPING and the flow time discretization method set to RUNGE-KUTTA_EXPLICIT, the solution does not show any evolution of the flow field. It was run for more than 100,000 iterations, but I expected to start seeing changes in the flow field after 500 iterations. I am starting from a restart file that was run to steady-state convergence over 3.1 million iterations.
I use ExtIter to start the activation of the forcing term. Would the implementation need to change for TIME_STEPPING? How does TIME_STEPPING differ from the dual time stepping mode? I haven't been able to find any documentation on the TIME_STEPPING mode specifically, the SU2 tutorials deal with 2nd order dual time stepping. |
unsteady simulation with BC transition model in su2 | windywestlife | SU2 | 0 | April 20, 2019 01:16 |
Unsteady simulation of rotating duct SRF or Sliding mesh | Alisa_W | FLUENT | 7 | January 22, 2019 07:34 |
How to see temperature and velocity vector contour after unsteady simulation? | aja1345 | FLUENT | 3 | September 24, 2018 17:33 |
Unsteady RANS simulation of Jet in crossflow | harshad88 | FLUENT | 0 | June 2, 2013 14:29 |
Procedure to run unsteady simulation? | STN | Main CFD Forum | 2 | February 16, 2002 05:37 |
