Home > Forums > Software User Forums > SU2
simulate axisymmetric jet flow
Old   May 30, 2020, 02:44
Default simulate axisymmetric jet flow
xinlei91 is on a distinguished road
Hi
I am trying to use SU2 to simulate subsonic round jet flow. The case is from NASA TMR (https://turbmodels.larc.nasa.gov/jet...ichot_val.html). I use the 2D mesh and set Axisymmetric=YES. But the solver diverges. I cannot figure out the reason. It would be greatly appreciated if anybody can give me some guidance. The attached is cfg and mesh files.
xinlei91 is offline   Reply With Quote
Old   June 11, 2020, 03:13
Jose Daniel
jdp810 is on a distinguished road
Try lowering the CFL number and not using the CFL adaptation, it may help to converge
jdp810 is offline   Reply With Quote
Old   July 23, 2021, 10:47
PENG YAN
PENGGEGE777 is on a distinguished road
Actullay, I check your config file, and I do not know why there is a 'MARKER_FAR' BC, since in a nozzle, there should be no far field BC.
PENGGEGE777 is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
swirl inlet velocity for a 2-d axisymmetric flow zahrarashidi OpenFOAM Running, Solving & CFD 2 January 12, 2015 07:01
how to simulate jet flow? Benny FLUENT 18 May 12, 2014 10:53
simulate the flow and reactive flow in a catalytic convertor aban OpenFOAM 2 February 12, 2014 10:29
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 13:38
