Home > Forums > Software User Forums > SU2
SU2_DOT_AD: Sensitivity x not found in file
Old   May 27, 2020, 12:26
Default SU2_DOT_AD: Sensitivity x not found in file
tom pratt
tomp1993 is on a distinguished road
Hello All
I have run a flow and adjoint problem with SU2 v7.0 in the same way i used to with v6.2, and both have converged as expected.
When i go to visualise the adjoint solution in paraview, i can only see the variables: adjoint density, adjoint momentum and adjoint energy in the .vtu file.
So, i ran SU2_DOT_AD in the hopes it would output surface_sensitivity.vtu, however all it does is give the output:
Error in "virtual void CPhysicalGeometry::SetSensitivity(CConfig*)":
Sensitivity x not found in file.
------------------------------ Error Exit -------------------------------
Is there an option in the config file that somehow switched this off or caused the sensitivities to not be saved? i am using a modified version of config-template-v7.cfg
Thanks!
Tom
tomp1993 is offline   Reply With Quote
Old   May 27, 2020, 18:59
Ole Burghardt
Sprotte is on a distinguished road
SU2_DOT_AD should read in the mesh sensitivities from the adjoint solution file, not from a visualization file. Could you have a look what's in solution_adj_* ?
Unless you didn't touch the volume output option, they should be included...
Best, Ole
Sprotte is offline   Reply With Quote
Old   May 29, 2020, 10:24
Tim Albring
talbring is on a distinguished road
Hi Tom,
the problem was that the sensitivity was not added by default. Should be solved with version 7.0.5 which was just released.
Best,
Tim
Developer Director @ SU2 Foundation
Get involved:
talbring is offline   Reply With Quote
discrete adjoint, sensitivity, su2 v7, su2_dot, su2_dot_ad
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
