Home > Forums > Software User Forums > SU2
Multizone case setup
Old   May 20, 2020, 18:28
Question Multizone case setup
Wenqiang is on a distinguished road
Hope everything is good. Now I try to run a very simple test case with multizone.
I have attached the screenshot of the domain in this post. The domain is composed of two ducts, every duct has 6 surfaces: inlet and outlet, then the other 4 surfaces are all wall. What I did is to attach the inlet of zone 2 to the outlet of zone 1, and I can make sure that these two surface are exactly the same, they both have the same axial coordinates.
I generate the mesh in SU2 native format, and use markers like NZONE, IZONE as the tutorial online: https://su2code.github.io/docs_v7/Multizone/
I name the surface from 1 to 12. Face 1 is the inlet surface of zone 1, surface 2 is its outlet surface. Surface 3-6 are wall; Face 7 is the inlet surface of zone 2, Face 8 is the outlet surface of zone 2 and surface 9-12 are wall. In the .cfg file, I have following setup:
MULTIZONE = YES
MARKER_INTERNAL=(face2,face7)
MARKER_EULER= ( face3, face4, face5,face6,face9,face10,face11,face12 )
and for boundary conditions:
INLET_TYPE= TOTAL_CONDITIONS
MARKER_INLET= ( face1, 288.6, 102010.0, 1.0, 0.0, 0.0 )
MARKER_OUTLET= ( face8, 101300.0 )
This is a single physics simulation, both zones are stationary and there is special setup, so I guess I do not need any subcfg files.
I use "OUTER_ITER= 50" and try to run it, but it always diverges and crashes after about 10 iterations.
I do not know if my setup are suitable. I tested each single zone mesh and run it using exactly the same boundary condition, I can get reasonable results. So I think there is nothing wrong with the mesh. Could anyone tell me if I need to change anything in the .cfg file? I also attached it in this post (I rename it as two.txt, or it cannot be uploaded). Thank you.
kind regards,
Wenqiang
File Type: png Screenshot from 2020-05-20 22-27-06.png (61.1 KB, 31 views)
Wenqiang is offline   Reply With Quote
Old   May 20, 2020, 19:21
pcg
Pedro Gomes
pcg is on a distinguished road
You need to define the fluid interface between your zones using MARKER_ZONE_INTERFACE and MARKER_FLUID_INTERFACE.
MARKER_INTERNAL does not do anything, it is a "fictitious" boundary condition.
You can have a look at the examples in SU2/TestCases/sliding_interface.
pcg is offline   Reply With Quote
Old   May 21, 2020, 08:30
Originally Posted by pcg View Post
Thank you so much for your reply. I checked the sliding plane example as you suggested. Then I put these two lines in my .cfg file as well as "MULTIZONE_SOLVER=BLOCK_JACOBI". But even I tried that, it still diverges. The density becomes very large.
This time I generated a much smaller mesh as following picture. So it is much quicker to test it. I also attached my .cfg file again, named as "two.txt". I also uploaded the mesh file I used here:
https://drive.google.com/open?id=1mE...A5R8wQhZERg6CE
As I mentioned, this zone1+zone2 mesh just comes from zone1, and I tested running zone 1 alone, everything is fine. Zone 2 mesh is just a copy of zone1 but the coordinates has been moved along the x direction to match surface 2 and surface 7.
So is there still anything wrong with my setup or mesh? Thank you so much.
File Type: png Screenshot from 2020-05-21 12-18-57.png (119.7 KB, 8 views)
Pressure instabilities with interDyMFoam for the floatingObject case nbadano OpenFOAM Running, Solving & CFD 15 October 15, 2021 07:35
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
Piston-Cylinder Pressure Driven Flow Case Setup Ballistics_Sim OpenFOAM Pre-Processing 0 February 2, 2018 10:11
Can`t Setup ONERA optimization case McAero SU2 6 November 15, 2017 09:29
OpenFOAM Case Setup Needed mpl CFD Freelancers 4 October 10, 2013 17:14
