Home > Forums > Software User Forums > SU2
Pitching NACA64A010
Old   May 15, 2020, 17:38
Default Pitching NACA64A010
wystone is on a distinguished road
HELLO,
I am trying to run the pitching NACA64A010 unsteady case with SU2 7.0.4. However, large discrepancy was observed between the results of SU2 6.2 and SU2 7.0.4 when using the same CFD set-up. It seems to me that the SU2 7.0.4 somehow produces wrong moment, whereas the results of SU2 6.2 agree well with the literature. Does anyone have the similar problems?
Thanks.
wystone is offline   Reply With Quote
Old   May 23, 2020, 12:39
pro
pro_ is on a distinguished road
What was the literature you were referring to? For my pitch-plunge case I do see a difference
pro_ is offline   Reply With Quote
Old   May 27, 2020, 11:25
na
TKatt is on a distinguished road
Hi wystone,
To make it short: there was a bug which was just worked out regarding grid velocities on Euler/Symmetry walls. I hope that it will be in the next SU2 stable version soon. Until then you can check out the branch `fix_gridvel` and try the case with that.
I'll write a note here when that is merged.
I am optimistic that this will recover the results of 6.2
Cheers, Tobi
TKatt is offline   Reply With Quote
Old   May 29, 2020, 11:23
Hi TKatt,
Many thanks for the clarification. That will be great if the bug can be fixed in the next SU2 version.
Cheers.
Old   May 29, 2020, 14:15
pcg
Pedro Gomes
pcg is on a distinguished road
It should be fixed and the version got out today.
pcg is offline   Reply With Quote
Speed problem of periodic boundary condition imposed on pitching airfoil. TG777 OpenFOAM Running, Solving & CFD 1 March 20, 2020 17:33
Pitching NACA64A010 Test Case Error Buxwax SU2 Shape Design 2 March 7, 2019 15:24
Airfoil is not pitching as expected abonfi SU2 Shape Design 0 December 3, 2018 04:03
Pitching and Plunging problem in SU2 albinjohny SU2 Shape Design 1 July 5, 2015 02:54
pitching naca64a010 aerofoil euler tutorial pranav SU2 1 July 17, 2014 11:02
