May 8, 2020, 02:52 |
multiple parallel runs in multicore cpu
Hyun Ko
Rep Power: 17 |
I am using SU2 7.03 in AMD 3990x 64core cpu. I hope to run SU2 separately in same time. This is one job using 32 cores, and other job using 32 cores simultaneously. Is there any method to run like that? Now I am using parallel_computation.py to run the parallel simulation. Thanks in advance. |
May 8, 2020, 13:50 |
Wally Maier
Rep Power: 7 |
Hi Hyunko,
You should be able to run both cases simultaneously. You simply need to call parallel_computation twice! Be sure to run your cases in separate folders so your outputs don't overwrite eachother! Wally |
May 9, 2020, 01:41 |
Hyun Ko
Rep Power: 17 |
Thanks wallym.
I have tried two “parallel_computation.py -f test.cfg -n 32” in different folders. But the calculation speeds are different between two runs. These are same mesh, same cfg. The speed difference almost double. 1st 32core job shows 5sec/iter, 2nd shows 10/iter. Is there any method to make the calculation time even? |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing | Regis_ | OpenFOAM Meshing & Mesh Conversion | 2 | June 4, 2015 14:44 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
Difference between processor CPU core in parallel launch | woodwick | Hardware | 1 | November 16, 2013 12:14 |
CFX-5.7.1(Linux) Parallel - 4 CPU Machine | James Date | CFX | 6 | June 14, 2005 19:03 |
