Home > Forums > Software User Forums > SU2
Propellor actuator-disk setup
Old   April 28, 2020, 09:26
Default Propellor actuator-disk setup
tom pratt
tomp1993 is on a distinguished road
Hi all,
I am trying to simulate an engine nacelle with an actuator disk propellor in very slow external flow, but with a fairly large pressure jump across the disk.
In my results i am seeing no flow through the disk and a very large 'separation' or recirculation zone behind the disk, making it seem like the disk is being modelled as a solid surface.
In my mesh, i have the upwind (suction) side of the prop disk called 'PROP-UP' and the downwind (pressure) side called 'PROP-DOWN'.
in my configuration file, i have used the options:
ACTDISK_TYPE= VARIABLES_JUMP
ACTDISK_DOUBLE_SURFACE= YES
MARKER_ACTDISK= ( PROPDISK-DOWN, PROPDISK-UP, 2500, 0.0, 0.0, 2500, 0.0, 0.0 )
Here, i have specified the pressure jump in Pa instead of PSF since i chose SI units for the simulation.
I have also tried running the simulation with down and up in the opposite positions in MARKER_ACTDISK to see if i had the actdisk pushing air the wrong way but got more or less the same result.
I am using version 6.2.0 falcon.
Any help understanding why this is happening would be very much appreciated.
tomp1993 is offline   Reply With Quote
Old   February 10, 2021, 07:48
Jose Daniel
jdp810 is on a distinguished road
Have you solved it? I am interested in the problem
jdp810 is offline   Reply With Quote
Taylor Couette Setup and Boundary Conditions DaSh OpenFOAM Pre-Processing 2 September 28, 2017 13:02
2D Glass Melt Simulation Setup marmz FLUENT 5 October 9, 2016 16:25
[OpenFOAM.org] OpenFOAM Cluster Setup for Beginners Ruli OpenFOAM Installation 7 July 22, 2016 05:14
[ICEM] surface/curve mesh setup Studi ANSYS Meshing & Geometry 15 November 12, 2014 01:32
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
