SU2 does not rebuild some codes on latest Develop version |
April 16, 2020, 00:16 |
Marrie
Greetings,
I've been playing around with the SU2 code to try to add things and contribute. On the latest develop branch, as of April 15th 2020, some codes do not recompile after I make some changes. I am not sure if this will affect other files too but currently, I have problem with the file SU2_SOL.cpp within SU2_SOL/src directory. My test problem is the Inviscid Bump. Steps to reproduce 1. Go to SU2_SOL/src/SU2_SOL.cpp, I change just the string at line 725, which outputs "Solver Postprocessing". I didnt want to break other things so I figure changing string is a safe option. 2. In other words, I change: Code:
cout << endl <<"------------------------- Solver Postprocessing -------------------------" << endl; Code:
cout << endl <<"------------------------- CHANGE Solver Postprocessing -------------------------" << endl; 3. I also changed the output string of the file CSinglezoneDriver.cpp within SU2_CFD/src/drivers directory. This is to check if only SU2_SOL.cpp are affected. For this file, I changed line 270 which outputs "Solver Exit" like this: Code:
cout << endl << "----------------------------- Solver Exit -------------------------------" << endl; Code:
cout << endl << "---------------------------CHANGE Solver Exit -------------------------------" << endl; Code:
./meson.py build --reconfigure --buildtype=debug 5. Then to reinstall the code, I do: Code:
./ninja -C build install 6. I run the code to solve the Inviscid Bump using: Code:
SU2_CFD inv_channel.cfg Code runs and exits normal. The file CSinglezoneDriver.cpp is updated, but not the SU2_SOL.cpp. I tried removing the build folder to do a fresh build and install, still the same problem. The only thing I changed within the config file is setting ROE as flow numerical method (line 145). I also changed the iteration on line 102 to like 2 iteration, because I only want to see if the files get updated. I have not created an Issue on Github yet, just want to know the suggestions here first. Please let me know and I appreciate the inputs |
April 16, 2020, 13:46 |
Marrie
I figured out the problem. I was editing the wrong file, every solver has the "Exit" and "Deleted" messages printed out. I was editting the SU2_SOL.cpp, but in fact the file that needs to be changed is the CDrivers.cpp within SU2_CFD.
build, compile from source, update |
Problems with CGNS mesh and develop version | BopngMa | SU2 | 2 | September 15, 2015 16:38 |
Porting FoamX to cygwin using the latest version of MICO | 7islands | OpenFOAM Pre-Processing | 17 | December 31, 2008 01:27 |
What is Fluent's latest version number and service | JollyP | FLUENT | 1 | October 30, 2006 16:34 |
The latest version | Ivan | Siemens | 1 | August 29, 2006 09:28 |
latest version of fluent | masood yooceframandi | FLUENT | 10 | January 22, 2005 18:21 |
