Home > Forums > Software User Forums > SU2
Dynamic Mesh Definitions
Old   April 11, 2020, 10:22
Question Dynamic Mesh Definitions
pro
pro_ is on a distinguished road
I would like to know the definitions of the dynamic mesh definitions. I have a list of questions. My specific case is simulating a unsteady compressible Euler flow for a (2D) pitch-plunge airfoil.
1. What is the difference between Grid movement and Surface movement. Do both deform the mesh? For example, In the provided pitching test case (/unsteady) it uses the SURFACE_MOVEMENT= DEFORMING. Whereas, the plunging test case uses GRID_MOVEMENT= RIGID_MOTION.
2. What is the AEROELASTIC surface movement and how does is differ from the other movements?
3. I am interested in predicting the flutter boundary based on the time history of the pitch and plunge. Would the grid movement FLUTTER be appropriate to use?
4. Since I am running an unsteady case of both pitch and plunge which would be appropriate to use GRID_MOVEMENT or SURFACE_MOVEMENT (this question is due to the fact that i do not know the difference between the two)
pro_ is offline   Reply With Quote
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 09:27
Sliding / Dynamic Mesh in heat transfer problem platzhalter FLUENT 0 May 7, 2018 06:25
[ICEM] Dynamic mesh setup with ICEM David121284 ANSYS Meshing & Geometry 0 April 11, 2014 05:19
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 23:09
dynamic mesh for drop interface IndrajitW FLUENT 0 March 30, 2013 09:03
