Umut Can
Rep Power: 13 ![]() |
I am trying to make a simple simulation for a ducted fan. Fan is going to be simulated as an actuator disk. I am creating mesh in Pointwise and for the actuator disk, I create baffle (infinitely thin but two sided surface mesh). I name upstream face of the baffle as act_disk_front and downstream face of the actuator disk as act_disk_back. When SU2 reads the mesh, it somehow duplicates act_disk_back and give me following error; 1622 boundary elements in index 0 (Marker = act_disk_back). 1622 boundary elements in index 1 (Marker = act_disk_front). 1622 boundary elements in index 2 (Marker = act_disk_back). 17926 boundary elements in index 3 (Marker = body). 6504 boundary elements in index 4 (Marker = pff). Executing the partitioning functions. Building the graph adjacency structure. Calling ParMETIS... graph partitioning complete (25199 edge cuts). Distributing ParMETIS coloring. [xtz:04508] *** Process received signal *** [xtz:04508] Signal: Segmentation fault (11) [xtz:04508] Signal code: Address not mapped (1) [xtz:04508] Failing at address: 0x51f64 I think code fails to map duplicate of act_disk_back. I cant figure out why code duplicates act_disk_back. SU2 version is 7.0.2 "Blackbird. Do u have any suggestion? |
Akshay Koodly
Rep Power: 9 ![]() |
Can you try to add this line to your config file and try? ACTDISK_DOUBLE_SURFACE = YES Also, would be helpful if you attach your config file or the boundary marker section here. Cheers, Akshay |
Umut Can
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[ICEM] ICEM Structured Mesh Problem | OMJT | ANSYS Meshing & Geometry | 3 | March 22, 2013 10:06 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
