Restart causes FGMRES orthogonalization failed |
David Stevens
Rep Power: 6 ![]() |
Hello all,
I am currently running a SS and transient model with and inlet profile and a rotating wall using a 3D hex mesh. I receive the following error whenever I attempt to restart the solution in SS or the time domain. This is the first time I have run into this and I have successfully performed similar operations in v7.0.0 in the past. I get the same error in v7.0.0 and 7.0.2. Error in "void CSysSolve<ScalarType>::ModGramSchmidt(int, std::vector<std::vector<ScalarType> >&, std::vector<CSysVector<ScalarType> >&) const [with ScalarType = double]": ------------------------------------------------------------------------- FGMRES orthogonalization failed, linear solver diverged. ------------------------------ Error Exit ------------------------------- Thank you! David W. Stevens Staff Engineer Peregrine Turbine Technologies |
Pedro Gomes
Rep Power: 13 ![]() |
Hello David,
Can you create a minimal case for which this happens and share it? Does SU2 also diverge with other linear solvers? If not, do the residuals shoot up upon restart? Are you using adaptive CFL? If so can you check if using a fixed (and maybe lower) CFL helps. Cheers, Pedro |
David Stevens
Pedro,
I turned off the rotating wall and the issue went away. My CFL is already quite low but I am going to try to lower it further. If I cant resolve it I will certainly send you a case. Thank you, David |
Pedro Gomes
I replicated the problem also on simpler cases, the status of this issue can be tracked via the SU2 GitHub https://github.com/su2code/SU2/issues/915
David Stevens
Thank you Pedro!
Pedro Gomes
Hi David,
The restart should work if the case was first run with the following option in the config file: VOLUME_OUTPUT= PRIMITIVE, GRID_VELOCITY (primitive variables are a default output, we need the grid velocities as extra for the restart to work) We will make this simpler on a future version (7.0.4 probably). Cheers, Pedro |
David Stevens
Pedro,
That works! Thank you for your help! David |
Vivek kumar
Rep Power: 5 ![]() |
I am getting error,
Last edited by vivekdixit194; March 3, 2021 at 05:16. Reason: image is not uploaded |
#9 |
Vivek kumar
Hello all,
I was trying to use RESTART for my next iteration in my unsteady case. So these changes I did, 1. WRT_BINARY_RESTART= YES READ_BINARY_RESTART= YES 2. RESTART_SOL= YES RESTART_ITER = 785 3. I renamed restart_flow.dat to solution_flow.dat after execution ------------------------------ Begin Solver ----------------------------- Simulation Run using the Multizone Driver The simulation will run for 3000 time steps. CSysSolve::ConjugateGradient(): system solved by initial guess. +-----------------------------------------------------------------------------+ | Multizone Summary | +-----------------------------------------------------------------------------+ | Time_Iter| Inner_Iter| Outer_Iter| avg[bgs][1]|MinVolume[0]|DeformIter[0| +-----------------------------------------------------------------------------+ | 785| 0| 0| -21.333333| 5.2486e-10| 0| Error in "void CSysSolve<ScalarType>::ModGramSchmidt(int, std::vector<std::vector<ScalarType> >&, std::vector<CSysVector<ScalarType> >&) const [with ScalarType = double]": ------------------------------------------------------------------------- FGMRES orthogonalization failed, linear solver diverged. ------------------------------ Error Exit ------------------------------- -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. PLEASE HELP ME |
diverged, error, fgmres, restart |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 15:00 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 09:54 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
