Inviscid Supersonic Wedge Tutorial similar mesh but different shock resolution? |
February 24, 2020, 22:30 |
Rahul
Hi Everyone,
I was testing "Inviscid Supersonic Wedge" tutorial from SU2 (v7.0.0) and observed some weird thing. Case 1: Download mesh (.cgns) and configuration file from "su2code.github.io/Inviscid_Wedge/" and run the case. Solution looks smooth near shock with .cgns mesh and even with .su2 mesh generated using SU2_DEF. Case 2: Download configuration file only form github-SU2 and generate .su2 mesh using Gmsh with same number of nodes and elements as in tutorial mesh. But now the solution with this mesh file does not look smooth near shock. (see attached Mach contour). I checked both mesh, Gmsh generated and tutorial mesh in Paraview and both are exactly same and I am using same configuration file but still the results are different. Any suggestions on this?Why its happening? (.cfg and both mesh file attached). |
May 13, 2020, 17:14 |
I am interested in generating the same mesh, but I can't figure out how to refine the mesh near the shock using gmsh. Do you think you can share the .geo file, or the command lines you used in the script file to refine the mesh there?
May 13, 2020, 20:02 |
Pedro Gomes
Rep Power: 14 |
See my reply here: https://github.com/su2code/SU2/issue...ment-591947858 |
gmsh, inviscid, su2, supersonic, wedge |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
Mesh similar to tutorial 20 | Marie S | CFX | 1 | August 27, 2008 05:25 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
