Home > Forums > Software User Forums > SU2
Supersonic Outlet Boundary Conditions
Old   February 24, 2020, 06:24
Default Supersonic Outlet Boundary Conditions
Dylan
dysd is on a distinguished road
Hi everyone, I am a college student and I am working with SU2 as my end-of-degree project.
I am having trouble imposing the right BC in the outlet end when adapting the flatplate test case to a supersonic flow. I am trying to put Riemann BC but that's not working. I've also tried the MARKER_SUPERSONIC_OUTLET BC, but that doesn't seem to work either.
Could someone suggest how to approach this case?
dysd is offline   Reply With Quote
Old   February 24, 2020, 15:08
Wally Maier
wallym is on a distinguished road
Hi Dylan,
What seems to not be working in your simulation?
In any case, I would suggest using MARKER_OUTLET. The supersonic outlet will not properly work since there should be an area of subsonic flow. Let me know if this helps.
Best,
Wally
wallym is offline   Reply With Quote
Old   February 25, 2020, 04:08
Dylan
Thank you for your reply!
What happens is that the simulation converges to a wrong solution when I try with the Riemann BC. I've already tried the MARKER_OUTLET but in that case the simulation didn't even converge.
I could attach the .cfg file in case it helps.
flatplate, riemann, supersonic
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 06:53
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
interFoam (HELYX-OS) pressure boundary conditions SFr OpenFOAM Running, Solving & CFD 8 June 23, 2016 17:36
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
