Home > Forums > Software User Forums > SU2
Change of Binary Restart Format? [Solved]
Old   February 19, 2020, 19:32
Question Change of Binary Restart Format? [Solved]
Paul
GomerOfDoom is on a distinguished road
Solved my own problem. It does indeed appear that all metadata that used to follow the volume values has been removed.
Original question below:
I had previously written a python script to extract data from SU2 binary restart files.
The script worked for v. 6.2 and below, but I now seem to have problems with restart files from v. 7.0 and above.
I saw on the guide that the ASCII format has changed (certain metadata is no longer written). Does this also apply to the binary file format?
Is there a guide/specification on the binary restart file format as of version 7.0? If so, can someone point me to it?
Thanks!
-Paul
GomerOfDoom is offline   Reply With Quote
Old   May 24, 2020, 10:51
Smile
xinlei91 is on a distinguished road
Hi Paul,
Have you solved this problem? I am struggling to read the restart file with python. It would be greatly appreciated if you could give me some help on this.
Xinlei
xinlei91 is offline   Reply With Quote
Old   May 24, 2020, 22:13
DGIorio is on a distinguished road
Originally Posted by xinlei91 View Post
Hi Paul,
Xinlei
The restart file is stored in binary format. For steady bidimensional simulations, it's structured in the following way:
Offset Size Type Comment
0x00 0x4 int Magic, 0x82BEC
0x04 0x4 int Number of primary properties
0x08 0x4 int Number of data entries or number of mesh vertices
Following this header, at offset 0x14, you have the properties names in string format, each one with size 0x21.
Then there are the flow data, stored in double float format following the vertex order of your mesh (ie, first entry is related with vertex 1, second entry to vertex 2,...). For each vertex, the flow data is organized in the sequence presented in the properties names section.
DGIorio is offline   Reply With Quote
Old   May 25, 2020, 00:29
Thumbs up
Thanks for your answer! It is quite helpful.
reconstructPar error with binary format data Bashar OpenFOAM 1 April 22, 2021 12:53
save to variable filename inside loop FrankR Fluent UDF and Scheme Programming 5 January 30, 2019 12:16
Change BCs and restart simulation be89 OpenFOAM Running, Solving & CFD 1 February 28, 2017 13:02
Write data from probe locations in binary format kozden OpenFOAM Post-Processing 0 June 18, 2016 06:25
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
