February 10, 2020, 05:29 |
SU2 y+ calculation
Mehmet SAHIN
Rep Power: 14 |
When SU2 gives the y+ values on surface data file, how y value is computed in the following equation:
y+ = u_* y/\nu When l use anisotropic elements next to solid wall, l see that Cf_x value looks normal. When l go to y+, it is completely irregular. In SU2-6.2.0, the distance function is modified to the distance to surface, rather than surface grid nodes. I think currently y value is not using normal distance to surface, but the edge length. Can any one verify that? MS |
Introducing SU2 International Developers Society (IDS) | fpalacios | SU2 News & Announcements | 1 | June 17, 2019 22:38 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
Drag Calculation in SU2 | andromeda91 | SU2 | 3 | April 24, 2014 04:41 |
Incorrect calculation of forces/moments coefficients with older versions of SU2 | diwakaranant | SU2 | 2 | August 16, 2013 04:17 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
