Home > Forums > Software User Forums > SU2
Divergence in Nozzle
Old   December 11, 2019, 13:50
Default Divergence in Nozzle
jcownbey is on a distinguished road
I am trying to simulate an axisymmetric C-D nozzle at Mach 6 in SU2, but the solution keeps diverging after a few thousand iterations. Any recommendations to solve this issue? I've tried changing the CFL number, changing the relaxation coefficients, and changing the JST coefficients.
jcownbey is offline   Reply With Quote
Old   December 11, 2019, 15:54
Wally Maier
wallym is on a distinguished road
Hi jcrownbey,
Thanks for your question. How do the residuals evolve? What are your boundary conditions?
One thing that may help, would be to use the AUSM convective flux, as it is more suited for high speed flows. Disabling multigrid could help as well.
Let me know if this helps. Also, feel free to attach your config file so we can take a better look
Best,
Wally
wallym is offline   Reply With Quote
Old   December 11, 2019, 16:14
Wally,
Thank you for your response.
In a simulation I have done in a 2-D nozzle at Mach 2, I compared AUSM, ROE (2nd order), and JST. AUSM had too many oscillations in the solution.
Here is a piece of my config file for the BC's:
% -------------------- BOUNDARY CONDITION DEFINITION --------------------------%
% Euler wall boundary marker(s) (NONE = no marker)
MARKER_EULER= ( Wall )
% Navier-Stokes (no-slip), constant heat flux wall marker(s) (NONE = no marker)
% Format: ( marker name, constant heat flux (J/m^2), ... )
%MARKER_HEATFLUX= ( UPPER_WALL, 0.0, LOWER_WALL, 0.0 )
% Riemann boundary marker(s) (NONE = no marker)
% Format: (marker, data kind flag, list of data)
MARKER_RIEMANN= ( Inflow, TOTAL_CONDITIONS_PT,3618647, 1904.4, 1.0, 0.0, 0.0, Outflow, STATIC_PRESSURE, 2021.804, 0.0, 0.0, 0.0, 0.0)
MARKER_SYM= ( Symmetry ) % Symmetry boundary marker(s) (NONE = no marker)
Also, attached is a picture of the boundaries of my nozzle.
The left line is my Inflow, the top contour is a inviscid wall (inviscid solution), and the bottom line is my Symmetry. The box on the right of the nozzle is to simulate the nozzle after it exits to the atmosphere. The left line, top line, and right line of the box are set to Outflow.
I do not have mutigrid active for my simulation.
Old   December 11, 2019, 16:24
Wally Maier
Hmmm interesting. Your boundary conditions look good. Did ROE look good/converge? Are you running with version 7.0?
You could try running explicitly with a small CFL number (if you havent tried).
JST should be able to converge this so Im a bit stumped at the moment.
Old   December 11, 2019, 16:29
In the Mach-2 nozzle, ROE converged, but the solution was not as clean as JST. I have tried running with CFL_ADAPT on, but it still diverges. For the Mach-2 nozzle, I had to run with a CFL no. of 10 to get a converged solution.
I am running with version 6.2
Old   December 12, 2019, 03:16
atelcikti1's Avatar
atelcikti1 is on a distinguished road
Did you add to your config file to represent axisymmetry?
% Dimension of problem (YES, NO)
AXISYMMETRIC = YES
atelcikti1 is offline   Reply With Quote
Old   December 12, 2019, 11:47
I did have the axisymmetric option on
Old   December 12, 2019, 15:22
The simulation works fine for a thousand iterations or so. The solution then diverges, usually having non-physical points after a while.
Old   December 13, 2019, 04:21
Tim Albring
talbring is on a distinguished road
Its hard to give some support for older versions. Think about using the v7 and try your case again.
Developer Director @ SU2 Foundation
Get involved:
talbring is offline   Reply With Quote
Old   December 13, 2019, 07:55
After looking at the additions to the new version, the only way I would be affected is the variables names would be changed.
divergence, hypersonics, nozzle
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 16:44
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
Convergent-Divergent Nozzle Divergence aeronautics FLUENT 6 August 30, 2018 03:57
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
Divergence problem Smaras FLUENT 13 February 21, 2013 06:03
