December 9, 2019, 12:00 |
SU2 v7: Forces breakdown file?
Brandon Gleeson
Rep Power: 8 |
After updating to v7.0 from v6.2, I'm no longer seeing the forces breakdown *.dat file being written at the end of solutions.
i.e., this parameter in the config file: % Output file with the forces breakdown BREAKDOWN_FILENAME= forces_breakdown.dat Perhaps this file needs to be added to the (new) list of output files to write, but I cannot find they keyword for this option: https://su2code.github.io/docs_v7/Custom-Output/ % Files to output OUTPUT_FILES= (RESTART, PARAVIEW, SURFACE_PARAVIEW, ??<something for FORCES_BREAKDOWN??? ) Has anybody run across this or a solution for it? Thanks, Brandon |
December 10, 2019, 03:58 |
Tim Albring
Rep Power: 11 |
You can enable the writing if the breakdown file by setting WRT_FORCES_BREAKDOWN to YES. We actually forgot to document that, thanks for the hint!
Developer Director @ SU2 Foundation Get involved:
December 10, 2019, 09:58 |
Brandon Gleeson
Rep Power: 8 |
Great, thanks Tim for your help! The documentation for v7.0.0 has been a great improvement, keep up the good work!
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 04:52 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 13:41 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
