Home > Forums > Software User Forums > SU2
complex shape of the FFD box question
Old   November 28, 2019, 19:55
Default complex shape of the FFD box question
Stanislav Karpuk
StanislavKarpuk is on a distinguished road
I am trying to make an aerodynamic optimization of a BWB using SU2. It is not possible to fit a rectangular FFD box without compromising the number of control point for the outer portion of the wing, However, I have noticed that the Su2 code can read multiple corner points, so maybe it is possible to create a more complicated FFD box. Do you know anything about that?
Also, is multiple FFD boxes is the only way to handle this problem, then could you attach an example script with multiple FFD box definition? I have read the forum thread about that, but had no luck making it work in my case.
Thank you,
Stanislav Karpuk
StanislavKarpuk is offline   Reply With Quote
complex ffd, ffd, ffd child box, ffd_parents
FFD 2D for inverse shape design using target CP ericclaro SU2 Shape Design 1 May 30, 2019 19:53
A question about species box of species transport model tjushang FLUENT 2 June 25, 2014 08:56
Simple CFD question for those in the know judderod Main CFD Forum 8 August 5, 2011 12:05
problem when running icoFoam on a complex shape flow field wendywu OpenFOAM 1 May 21, 2009 00:40
Question from a non-Fluid person ozzy Main CFD Forum 6 September 4, 1998 05:09
