Adjoint FFD Wing optimization convergence controllers |
November 15, 2019, 04:18 |
Stanislav Karpuk
Rep Power: 10 |
I have a little problem with setting the coefficients up for the wing optimization using FFD. Everything is working fine, but my adjoint solution takes way too long and converges to really small values I do not need. Can anybody tell me what parameters I need to change, so my convergence is stopped a bit earlier, Last lines of the adjoint convergence log10[Maximum residual]: -1.6298e+01. Maximum residual point 1103, located at (-1.9286e+02, 3.8571e+02, -4.5000e+02). Iter Time(s) Res[Psi_Rho] Res[Psi_E] Sens_Press Sens_AoA 2480 0.635330 -18.364197 -18.736024 -5.4461e-02 -2.4966e-03 2481 0.635222 -18.318372 -18.717016 -5.4461e-02 -2.4966e-03 2482 0.635114 -18.351926 -18.744432 -5.4461e-02 -2.4966e-03 2483 0.635005 -18.387036 -18.736493 -5.4461e-02 -2.4966e-03 2484 0.634907 -18.379428 -18.740495 -5.4461e-02 -2.4966e-03 2485 0.634804 -18.372618 -18.700524 -5.4461e-02 -2.4966e-03 2486 0.634697 -18.402309 -18.784623 -5.4461e-02 -2.4966e-03 2487 0.634589 -18.331247 -18.702867 -5.4461e-02 -2.4966e-03 2488 0.634481 -18.326309 -18.741878 -5.4461e-02 -2.4966e-03 2489 0.634376 -18.363654 -18.749159 -5.4461e-02 -2.4966e-03 2490 0.634268 -18.340797 -18.710770 -5.4461e-02 -2.4966e-03 2491 0.634163 -18.358591 -18.752570 -5.4461e-02 -2.4966e-03 2492 0.634058 -18.367746 -18.768742 -5.4461e-02 -2.4966e-03 2493 0.633951 -18.364933 -18.775686 -5.4461e-02 -2.4966e-03 2494 0.633843 -18.360979 -18.767785 -5.4461e-02 -2.4966e-03 2495 0.633736 -18.327877 -18.686616 -5.4461e-02 -2.4966e-03 2496 0.633629 -18.361588 -18.736146 -5.4461e-02 -2.4966e-03 2497 0.633522 -18.358536 -18.751150 -5.4461e-02 -2.4966e-03 2498 0.633415 -18.387406 -18.729346 -5.4461e-02 -2.4966e-03 2499 0.633308 -18.392014 -18.777462 -5.4461e-02 -2.4966e-03 -------------------------- File Output Summary -------------------------- Writing comma-separated values (CSV) surface files. Loading solution output data locally on each rank. Sorting output data across all ranks. Writing binary SU2 native restart file. ------------------------------------------------------------------------- 2500 0.636858 -18.366780 -18.749547 -5.4461e-02 -2.4966e-03 2550 0.636943 -8.149034 -8.656327 -5.4453e-02 -2.4950e-03 2600 0.637018 -8.182186 -8.654305 -5.4360e-02 -2.4947e-03 2650 0.636950 -8.422885 -8.899310 -5.4400e-02 -2.4946e-03 2700 0.637045 -8.922409 -9.403217 -5.4422e-02 -2.4946e-03 2750 0.636958 -9.222539 -9.709249 -5.4410e-02 -2.4946e-03 2800 0.636749 -9.782752 -10.299221 -5.4415e-02 -2.4946e-03 2850 0.636529 -9.901253 -10.382556 -5.4415e-02 -2.4946e-03 2900 0.636331 -10.070406 -10.548106 -5.4414e-02 -2.4946e-03 2950 0.636126 -10.518349 -11.009703 -5.4415e-02 -2.4946e-03 Thank you, Stan |
Continuity convergence issue on a 3d wing | Nick R | FLUENT | 19 | April 6, 2020 14:52 |
FFD box and wing section twist | Marco_Vanderbijl | SU2 Shape Design | 0 | May 17, 2019 16:46 |
Fluent Adjoint Solver Convergence Issue? | ex10148 | FLUENT | 2 | July 25, 2016 14:41 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Simple single element wing convergence | Jonny6001 | FLUENT | 0 | March 10, 2010 05:01 |
