SU2_MSH execution problem during parallel run |
November 7, 2019, 08:05 |
I executed SU2_MSH for my external aerodynamics case successfully in serial case. However, I am getting core dump while executing with mpirun, although solution was generated via parallel execution of SU2_CFD. The output of the erroneous execution is attached. I would be thankful if anyone can help in this issue. |
November 21, 2019, 05:57 |
Kaan
Rep Power: 8 |
I got similar error while trying execute SU2_MSH in parallel. I guess this executable does not work in parallel. I made mesh adaptation in serial with SU2_MSH succesfully. |
Problem with foam-extend 4.0 ggi parallel run | Metikurke | OpenFOAM Running, Solving & CFD | 1 | December 6, 2018 15:51 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Parallel interDyMFoam cellLevel problem | tgvosk | OpenFOAM Running, Solving & CFD | 5 | February 19, 2014 02:24 |
Problem in parallel run on 2 machine | Tush | OpenFOAM | 1 | October 19, 2012 06:24 |
Problem with parallel run | Whyman | OpenFOAM | 2 | October 3, 2012 06:48 |
