October 8, 2019, 12:32 |
Inlet Boundary conditions
PENANG
Rep Power: 9 |
I am getting errors for boundary conditions. HEre is the error;
Error in "void CConfig::SetPostprocessing(short unsigned int, short unsigned int, short unsigned int)": ------------------------------------------------------------------------- Inlet types for incompressible problem improperly specified. Use INC_INLET_TYPE= VELOCITY_INLET or PRESSURE_INLET. Must list a type for each inlet marker, including duplicates, e.g., INC_INLET_TYPE= VELOCITY_INLET VELOCITY_INLET PRESSURE_INLET ------------------------------ Error Exit ------------------------------- my .cfg file is attached. Thank you very much. |
October 11, 2019, 16:54 |
Wally Maier
Rep Power: 7 |
Hi Musa,
Thanks for using SU2! When running in-compressible simulations with an inlet, you must specify a INC_INLET_TYPE. Currently, you have specified its INLET_TYPE for compressible flows. The SU2 github page has config_template.cfg that has most of the options available listed. You can also find some example in the tutorials section. This one has the correct options specified, I believe: https://su2code.github.io/tutorials/...cid_Hydrofoil/ Hope this helps, Wally |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 17:19 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
