Home > Forums > Software User Forums > SU2
FEM_EULER vs. EULER Setup?
Old   October 4, 2019, 18:53
Default FEM_EULER vs. EULER Setup?
Brandon Gleeson
CSMDakota is on a distinguished road
I have a simple converging diverging nozzle case with a hexahedral mesh that converges OK to 12 orders residual reduction using traditional FVM "EULER" solver with SU2 (v6.2). I'd like to experiment with the FEM_EULER DG solver in SU2, but haven't found much documentation or examples. When I try to run with FEM_EULER, the solution throws an early error during the Geometry Preprocessing:
Error in "void CMeshFEM_DG::CreateFaces(CConfig*))":
Boundary face not found in localFaces. This should not happen.
Any suggestions on this error?
Thanks!
Brandon
CSMDakota is offline   Reply With Quote
Old   October 16, 2019, 14:13
pcg
Pedro Gomes
pcg is on a distinguished road
You need a high order mesh to run the high order (FEM) solver, as with all SU2 features the best line of action is to start from a working example and go from there, making incremental changes.
Clone the TestCase repo and have a look at the ones in folders with prefix "hom_" (high order methods).
There is only one developer for those solvers (and I'm not him) so I cannot help much more.
pcg is offline   Reply With Quote
Old   October 16, 2019, 14:58
Brandon Gleeson
Thanks, Pedro - this helps, I wasn't using a higher order mesh, assumed the quadrature points would be generated by the solver on the base grid. I will have a look at the examples in the repo.
Euler unsteady with moving boundary conditions - problem setup rocco.bom SU2 0 January 24, 2017 10:11
2D Glass Melt Simulation Setup marmz FLUENT 5 October 9, 2016 16:25
hard to convergent with SU2 4.0 for Euler adjoint Xianguu SU2 1 July 14, 2015 18:09
[ICEM] surface/curve mesh setup Studi ANSYS Meshing & Geometry 15 November 12, 2014 01:32
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
