Home > Forums > Software User Forums > SU2
mesh morphing to manually transform a patch
Old   September 16, 2019, 04:37
Default mesh morphing to manually transform a patch
William Tougeron
taalf is on a distinguished road
Hi all,
In the config_template.cfg file from SU2 6.2, one can find (line 1069):
% - TRANSLATE_GRID ( x_Disp, y_Disp, z_Disp ), as a unit vector
% - ROTATE_GRID ( x_Orig, y_Orig, z_Orig, x_End, y_End, z_End ) axis, DV_VALUE in deg.
Is it possible to apply this transform only on some patch(es) selected using DV_MARKER, so that other patches stay untouched and the internal mesh is morphed?
Best regards,
taalf is offline   Reply With Quote
Old   September 16, 2019, 06:51
pcg
Pedro Gomes
pcg is on a distinguished road
I believe those are rigid body motions only.
pcg is offline   Reply With Quote
Old   September 16, 2019, 08:45
William Tougeron
Could do the job using the DV_KIND= SURFACE_FILE approach (cf. tutorial SU2-6.2.0/TestCases/deformation/naca0012).
By launching SU2_DEF a first time, it creates some file containing all points of selected patches. Then, one edits this file with desired point coordinates after deformation, then re-launch SU2_DEF.
For translation, this is straighforward. For rotation, this needs a bit of scripting to edit the file.
Important parameters are also in the "GRID DEFORMATION PARAMETERS" section. I changed the DEFORM_STIFFNESS_TYPE value from INVERSE_VOLUME to WALL_DISTANCE to have cleaner results.
Hope this can help some more people.
All the best,
manual, marker, morphing, patch, su2
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
[Commercial meshers] Thin Walls Conversion from Fluent Mesh Isaac OpenFOAM Meshing & Mesh Conversion 1 March 4, 2016 13:08
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 12:25
