Home > Forums > Software User Forums > SU2
Optimization Constraints
Old   June 29, 2019, 13:56
Default Optimization Constraints
Drashan Y.N
darshangowda046 is on a distinguished road
i Followed all the steps given for ONERA_M6 but at last step it says Execute the shape optimization script by entering $ shape_optimization.py -g DISCRETE_ADJOINT -f inv_ONERAM6_adv.cfg. But the system says "The system cannot execute the specified program.". Traceback (most recent call last):
File "shape_optimization.py", line 40, in <module>
sys.path.append(os.environ['SU2_RUN'])
File "C:\Users\dharshan\Anaconda3\lib\os.py", line 678, in __getitem__
raise KeyError(key) from None
KeyError: 'SU2_RUN'
I used Anaconda Prompt
darshangowda046 is offline   Reply With Quote
Old   July 1, 2019, 12:43
Wally Maier
wallym is on a distinguished road
Thanks for using SU2.
One thing that may be causing this is that your environment variables aren't set properly. SU2_RUN is simply a path to the SU2_CFD executable. That is my guess of whats happening.
Im sure you have already checked here, but the instructions are here: https://su2code.github.io/docs/Windows-Installation/
Let us know if update your system path worked.
wallym is offline   Reply With Quote
onera m6, optimization parallel, su2 configuration file, su2 error
ANSYS Optimization failing to update Results component. harmollo1 ANSYS 1 March 21, 2019 16:30
MOGA Direct Optimization chris15012 ANSYS 0 February 17, 2019 15:55
2D Optimization Constraints Not Satisfied tomp1993 SU2 Shape Design 2 February 24, 2018 14:36
Multiple constraints for optimization problem diwakaranant SU2 1 August 12, 2014 19:52
Geometric Constraints and Gradients for Constrained Wing Optimization Tommy Chen SU2 5 January 29, 2014 12:00
