Home > Forums > Software User Forums > SU2
Convergence issues
Old   June 25, 2019, 12:09
Default Convergence issues
fluiddynamicsyay is on a distinguished road
Hello again! I am trying to run the hypersonic double cone case as a test (mesh attached), but SU2 diverges before displaying any iterations. The error it returns is:
Error in "void CIntegration::Convergence_Monitoring(CGeometry *, CConfig *, unsigned long, double, unsigned short)":
SU2 has diverged (NaN detected).
------------------------------ Error Exit -------------------------------
Full output is attached. What could be causing this?
Mesh and CFG: https://drive.google.com/file/d/1TC4...ew?usp=sharing
fluiddynamicsyay is offline   Reply With Quote
Old   June 25, 2019, 13:36
Wally Maier
wallym is on a distinguished road
I cant access your cfg/mesh files from where I am.
However, an instant divergence could suggest a few problems (not in any order of likelihood):
1.) Something is set incorrectly in preprocessing/SetNondimensional routines
2.) The mesh has some issues
3.) The numerical scheme has issues at large mach numbers.
I would suggest turning off multigrid to start. If you could post a .txt file of the config (not through google docs), I could take a look.
Best,
Wally
wallym is offline   Reply With Quote
Old   June 27, 2019, 14:49
I got it to work, thanks for the help!
Old   September 17, 2019, 04:21
Angu Praveen
angupraveen is on a distinguished road
could you tell me what the problem was?
angupraveen is offline   Reply With Quote
Convergence issues with heat transfer from tube wall Gadders FLUENT 3 October 12, 2015 10:03
rhoSimplecFoam convergence issues ufocfd OpenFOAM Running, Solving & CFD 0 August 28, 2015 01:37
Convergence issues for low Y plus values in Fluent NicoCFD FLUENT 1 February 4, 2015 11:55
Convergence Stability Issues ts_swati Fluent Multiphase 0 July 7, 2014 22:11
convergence issues (discontinuity mastered!) Matthew R FLUENT 0 October 12, 2006 04:55
