Rep Power: 9 ![]() |
Hi all,
I am trying to add an .hpp and .cpp file to Common/include and Common/src, but am have trouble building SU2. I'm 99% sure the issue lies within my Common/lib/Makefile.am. I've edited Makefile.am to list my added files and I have gone through the autotools documentation a few times, but still not sure what I'm doing wrong. The error I get when trying to make SU2 is: make[1]: *** No rule to make target '../src/MYNEWFILE.cpp', needed by '../src/libSU2Core_a-MYNEWFILE.o'. Stop. Makefile:441: recipe for target 'install-recursive' failed make: *** [install-recursive] Error 1 My procedure for building everything is as follows: $ ./bootstrap (according to the documentation this will also call autreconf and remake Configuration and Makefile.in 's ) $ ./configure --prefix=/home/user/Documents/SU2-6.2.0 CXXFLAGS="-O3" --enable-mpi --with-cc=/usr/bin/mpicc --with-cxx=/usr/bin/mpicxx $ make -j 16 install Could someone please give me a very explicit example of editing Makefile.am and re-building SU2? Thank you Last edited by asdfasdf; June 25, 2019 at 00:19. Reason: too much whitespace |
Update:
Took my code from Ubuntu 16.04 to a CentOS 7 machine and everything compiled just fine. I don't understand why its working now, but I'm not complaining |
Pedro Gomes
Rep Power: 13 ![]() |
Always good to do a "make clean" after changes to make files, just in case...
#4 | |
Heather Kline
Rep Power: 14 ![]() |
What the error you had often indicates is that the object (*.o) files from a previous compilation are confusing the compiler because of a change in the dependencies between files. The compiler will often not recompile an object if it's source hasn't been updated - but as you have found this can miss things when there is a new file dependency that was not there before. You can get around this either by using 'make clean' as a previous commentor stated (which removes ALL the object files), or by deleting just the .o file that's causing the problem if you'd like to try and save some time during the compilation process. Using 'make clean' is generally the safer bet. You can also use 'touch filename.cpp' to update the timestamp on the files giving the errors and trick the compiler into thinking it's been updated recently. |
automake, autotools, su2 |
chtMultiRegionSimpleFoam 3D problem | Lucie | OpenFOAM Pre-Processing | 2 | June 21, 2016 05:23 |
UDF help for Rapid compression machine ECM. | sanjeetlimbu | Fluent UDF and Scheme Programming | 0 | March 17, 2015 22:45 |
Help with chtMultiRegionFoam | jbvw96 | OpenFOAM Running, Solving & CFD | 2 | December 26, 2010 17:16 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
Merging .msh files in TGrid | Raza Mirza | FLUENT | 2 | January 18, 2001 18:09 |
