Home > Forums > Software User Forums > SU2
.cfg issues
Old   June 24, 2019, 16:52
Unhappy .cfg issues
Moshe Hollander
mhollander is on a distinguished road
Hi All,
I'm having some trouble with running a SU2 (6.2) simulation with a mesh generated with gmsh.
I have attached the .cfg (in .txt format as this forum won't let me upload anything with a .cfg extension) file here.
Whenever I try to run SU2, I end up getting the following:
Error in "short unsigned int CConfig::GetMarker_CfgFile_TagBound(std::__cxx11:: string)":
The configuration file doesn't have any definition for marker inlet
------------------------------ Error Exit -------------------------------
Has anyone else had this issue?
mhollander is offline   Reply With Quote
Old   June 24, 2019, 17:50
Wally Maier
wallym is on a distinguished road
I took a look at your cfg file and it seems there is corresponding boundary conditions for the inlet of your geometry. From what I can gather, you should have have something along the lines of MARKER_INLET(inlet,x,x,x,x).
wallym is offline   Reply With Quote
Old   June 24, 2019, 18:06
Moshe Hollander
Can you give a slightly more 'fleshed out' example?
I'm a little new to the SU2 and gmsh game
Old   June 24, 2019, 18:26
Wally Maier
Absolutely.
SU2 defines its boundary conditions using markers that are in the mesh.
For example, the config file you sent (fairing.txt) has MARKER_HEATFLUX(airfoil,0.0) and MARKER_FAR=(farfield).
This means SU2 will look for a tag within mesh called "airfoil" and assign the heatflux boundary condition to those cell. The same happens with the farfield tag.
Your error is saying that in your mesh file, you have a tag that is set to inlet. However, that portion of the boundary has no boundary assigned to it.
In this case, you can set your inlet condition with either MARKER_INLET=(inlet, total_temperature,t_pressure, dir_x,dir_y,dir_z). Or, depending on your inlet, using the MARKER_SUPERSONIC_INLET(inlet, temp, press,v_x,v_y,v_z).
You can see the options for boundary conditions in the config_template on github at https://github.com/su2code/SU2/blob/...g_template.cfg.
Please let me know if this helps, or if you have any more questions.
error, su2, su2 configuration file
chtMultiRegionSimpleFoam issues - non-conformal meshes & residual handling... manalis OpenFOAM Running, Solving & CFD 3 October 10, 2018 19:53
Convergence issues for Flat plate with sharp edge rajnarayang FLUENT 3 June 20, 2017 13:02
[ANSYS Meshing] Multizone issues (on my project) crenaudo ANSYS Meshing & Geometry 8 April 13, 2016 03:59
Multigrid Stability Issues ThomasHermann SU2 1 November 5, 2014 17:18
[General] Some Paraview Issues I can not solve MR_Chicho ParaView 1 September 24, 2012 06:03
