June 5, 2019, 09:11 |
how to specify periodic boundary conditions
Jianguo
Rep Power: 15 |
Hello friends,
I have a problem on the specification of periodic boundary conditions in SU2. I am using SU2 6.2 to simulate an 3D external flow around a 2D wing. The spanwise direction is in z direction. A 3D C-type grid is used, which is generated by translating a 2D mesh in x-y plane in z direction with uniform spanwise grid spacing. On the front and back surface of the resulting 3D mesh that are normal to z axis, the peridoic boundary (BC) conditions should be imposed. My question is: how can I specify the peridoic BC? According to the template configuration file, the peridoic BCshould be specified in the following way: % Periodic boundary marker(s) (NONE = no marker) % Format: ( periodic marker, donor marker, rotation_center_x, rotation_center_y, % rotation_center_z, rotation_angle_x-axis, rotation_angle_y-axis, % rotation_angle_z-axis, translation_x, translation_y, translation_z, ... ) MARKER_PERIODIC= ( ... ) But I do not understand the physical meaning of the above parameters. It would be greatly appreciate if anyone can help me resolve this problem. |
June 5, 2019, 14:22 |
#2 | |
Nitish Anand
Rep Power: 10 |
I have only used Periodic Boundary for turbomachinery simulations and should not be much different for your case. Use the following format MARKER_PERIODIC = (front_marker, back_marker, 0,0,0,0,0,0, translation_x, translation_y, translation_z) where front_marker and back_marker are your Mesh Markers. And rest defines where the doner markers lie with respect to the receiver marker. So if you have rotation you specify them in place of <0,0,0,0,0,0> but in your case, you want in terms of translation so you specify <translation_x, translation_y, translation_z>. This should solve your problem. Remember that you have to do SU2_PER to obtain the mesh with SEND RECEIVE marker and then run SU2_CFD to run CFD. Thanks Nitish |
June 5, 2019, 23:23 |
Jianguo
Rep Power: 15 |
Hi Nitis,
Thank for your help. I have implement the periodic BC with your method. An update is that in SU2 6.2, the SU2_MSH is used to generate the new mesh with periodic BC setting. JG |
June 6, 2019, 11:25 |
Nitish Anand
Rep Power: 10 |
Indeed !!
I am still using some older version hence SU2_PER. Glad that you figured it out already. Cheers, Nitish |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 05:53 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
PEMFC module + multiple periodic boundary conditions | vkrastev | FLUENT | 2 | December 22, 2014 04:15 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
