Home > Forums > Software User Forums > SU2
problem running wedge tutorial
Old   May 29, 2019, 01:51
Default problem running wedge tutorial
Dr. H.K. Narahari
hk.narahari is on a distinguished road
When I tried to run the inviscid supersonic wedge tutorial , I got the following error.
"mesh_wedge_inv.cgns is not in CGNS format. "
What am I doing wrong ? or is it possible that the mesh is corrupted
Regards and thanks in advance
Narahari
hk.narahari is offline   Reply With Quote
Old   May 29, 2019, 14:39
Wally Maier
wallym is on a distinguished road
Hi Narahari,
Thanks for using SU2! That is an interesting problem. My guess is something happened during the compilation process, or the option in the config is actually set to .su2.
My suggestion would be to check the config or got to https://github.com/su2code/TestCases...er/euler/wedge to download the .su2 mesh. (Sorry I am no good at the compiling stuff).
Please let me know if this helps,
Wally
wallym is offline   Reply With Quote
Old   June 16, 2019, 13:46
Dr. H.K. Narahari
Dear Wally,
Sorry, took a while to get around to testing it. As suggested I downloaded the mesh file but could not run as the code stops with a message like "SU2 has to stop "
Regards
Narahari
Old   June 16, 2019, 19:01
Wally Maier
Hi Narahari,
That's interesting that even the .su2 mesh failed. I don't seem to get a similar issue when running the test case. Could you post the exact error?
Thanks,
Wally
Old   June 17, 2019, 03:06
Dr. H.K. Narahari
Dear Wally,
I m attaching both the .CFG file and screen shot of the error message.
Thanks in advance
Narahari
Old   June 18, 2019, 00:13
Wally Maier
I took a look at your config...it looks fine. I have a suspicion that this is windows specific issue. I was able to run both the su2 and cgns meshes without a hitch on a linux machine.
Another suggestion would be to eliminate all options not concerning the direct solution.
Old   June 19, 2019, 05:33
Dr. H.K. Narahari
In another post of mine there was suggestion to remove Multigrid and use FGNRES, I tried it on and it worked for the Inviscid Wedge tutorial. Still exploring and wil update if I do figure out how and why this worked.
Thanks to all members who have taken the trouble to think over my issue.
Narahari
cgns file read, wedge tutorial
Error problem while running sadia d lts tutorial kane OpenFOAM Running, Solving & CFD 2 May 26, 2018 04:38
CFD Fluent tutorial - Shell and tube heat exchanger - PROBLEM tom96 FLUENT 1 May 21, 2018 01:24
Problem in running coarse mesh(on the other hand fine mesh is running) ashokmoravaneni OpenFOAM 7 July 17, 2017 05:56
Problem with running tutorial "Constrained Optimal Shape Design of a Fixed Wing" yugang881 SU2 12 February 3, 2017 08:15
Problem wirh Axial_Rotor_SRF tutorial run sam.ho OpenFOAM Running, Solving & CFD 0 February 6, 2014 07:30
