Home > Forums > Software User Forums > SU2
MUSCL and SLOPE LIMITER IN SU2
Old   May 28, 2019, 07:35
Default MUSCL and SLOPE LIMITER IN SU2
Muhammad Hilmi Al Fatih
hilmialf is on a distinguished road
Hello.
As far as I understand, MUSCL is used for higher order reconstruction and thus might somehow spurious oscillations in the region where discontinuity exists. To overcome this, one might add slope limiter to include a mechanism such that it switch to lower order scheme in the discontinuities.
My question is, I somehow found a strange configuration in one of the testcases as is attached below. I am now not really sure about my understanding thus could please someone explain a bit about it?
Here it is written for flow numerical method that it turns MUSCL_FLOW on, but SLOPE_LIMITER_FLOW is set to NONE. Does that mean the following lines specifying the VENKAT_LIMITER_COEFF become useless?
Moreover, for turbulent numerical method, it does not use MUSCL_TURB yet it somehow put SLOPE_LIMITER_TURB. Does this slope limiter affect then?
I hope someone can correct my understanding.
link to the cfg file: https://github.com/su2code/SU2/blob/...ST_RAE2822.cfg
Best regards,
Hilmi
File Type: png Screenshot from 2019-05-28 19-24-58.png (111.3 KB, 98 views)
hilmialf is offline   Reply With Quote
Old   May 28, 2019, 17:54
Amit
aero_amit is on a distinguished road
JST scheme is a central scheme. Here two dissipation terms (2nd order and 4th order) are used. 4th order dissipation is meant for suppressing the high frequency oscillations. Near to strong gradients like shock 2nd order dissipation becomes active and suppresses the overshoots (you can read the details online)
I think you don't need a limiter here unlike other second order cases. JST is a central scheme (second order accurate supplemented by dissipation terms with appropriate switches).
Regarding second part when MUSCL (MUSCL_TURB=No) is off, it won't use limiter as shown in your. cfg file.
Best
Amit
aero_amit is offline   Reply With Quote
Old   June 3, 2019, 02:22
Dear Amit,
Thank you for your reply. It is really helpful.
If I may, I would like to also ask if you know which kind of entropy fixing is used for ROE solver in SU2. Since as far as I understand there are a lot of algorithms proposed by different researcher to fix the entropy for roe solver.
Kind regards,
Hilmi
Old   June 5, 2019, 16:53
Amit
It uses Mavriplis entropy correction. You can check the numeric_direct_mean.cpp
Old   July 24, 2021, 07:09
Shenren Xu
Shenren_CN is on a distinguished road
Hi Amit,
Is there a publicly available reference on the so-called Mavriplis entropy correction?
Regards,
Shenren
Shenren_CN is offline   Reply With Quote
Doubt regarding MUSCL scheme implementation and associated limiters SangeethCFD Main CFD Forum 0 October 7, 2017 10:00
slope limiter for muscl Honglin Main CFD Forum 0 November 14, 2013 06:11
Slope limiter vs. Flux limiter jinwon park Main CFD Forum 3 September 11, 2007 11:55
limiter & entropy fix of Roe scheme kei-tee Main CFD Forum 21 May 26, 2003 06:50
