April 8, 2019, 18:56 |
SU2 Inviscid Hypersonic Solver Settings
Rep Power: 7 |
After looking online to see if any cases for hypersonic CFD on SU2 I can see that SU2 has the capability to solve problems like these, but have seen no documentation on the suggested solver settings. I am currently trying to run simulations on a body at M=5 for an inviscid test case and have been working off of the inviscid wedge tutorial for M=2 from github. I was wondering if anyone could either point me in the right direction as to a test case that has already been done in SU2 or similar suggested solver settings for this hypersonic case. What I am referring to for solver settings includes the spatial numerical method settings, multigrid vs no multigrid, and the convective numerical method. The ones selected for the wedge problem are seen below.
% ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % % Numerical method for spatial gradients (GREEN_GAUSS, LEAST_SQUARES, % WEIGHTED_LEAST_SQUARES) NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES % % Courant-Friedrichs-Lewy condition of the finest grid CFL_NUMBER= 5.0 % % Adaptive CFL number (NO, YES) CFL_ADAPT= NO % % Parameters of the adaptive CFL number (factor down, factor up, CFL min value, % CFL max value ) CFL_ADAPT_PARAM= ( 1.5, 0.5, 1.0, 100.0 ) % % Runge-Kutta alpha coefficients RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 ) % % Number of total iterations EXT_ITER= 1000 % % Linear solver for the implicit formulation (BCGSTAB, FGMRES) LINEAR_SOLVER= BCGSTAB % % Preconditioner of the Krylov linear solver (ILU, JACOBI, LINELET, LU_SGS) LINEAR_SOLVER_PREC= ILU % % Min error of the linear solver for the implicit formulation LINEAR_SOLVER_ERROR= 1E-6 % % Max number of iterations of the linear solver for the implicit formulation LINEAR_SOLVER_ITER= 5 % -------------------------- MULTIGRID PARAMETERS -----------------------------% % % Multi-Grid Levels (0 = no multi-grid) MGLEVEL= 2 % % Multi-grid cycle (V_CYCLE, W_CYCLE, FULLMG_CYCLE) MGCYCLE= V_CYCLE % % Multi-grid pre-smoothing level MG_PRE_SMOOTH= ( 1, 2, 3, 3 ) % % Multi-grid post-smoothing level MG_POST_SMOOTH= ( 0, 0, 0, 0 ) % % Jacobi implicit smoothing of the correction MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 ) % % Damping factor for the residual restriction MG_DAMP_RESTRICTION= 0.8 % % Damping factor for the correction prolongation MG_DAMP_PROLONGATION= 0.8 % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC, % TURKEL_PREC, MSW) CONV_NUM_METHOD_FLOW= HLLC % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the flow equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_FLOW= YES % % Slope limiter (NONE, VENKATAKRISHNAN, VENKATAKRISHNAN_WANG, % BARTH_JESPERSEN, VAN_ALBADA_EDGE) SLOPE_LIMITER_FLOW= NONE % % Coefficient for the limiter (smooth regions) VENKAT_LIMITER_COEFF= 0.006 % % 2nd and 4th order artificial dissipation coefficients JST_SENSOR_COEFF= ( 0.5, 0.02 ) % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT) TIME_DISCRE_FLOW= EULER_IMPLICIT |
April 10, 2019, 11:27 |
Amit
Rep Power: 13 |
Have a look at SU2 V6.2.0 test cases-
TestCases/euler/bluntbody/blunt.cfg |
April 10, 2019, 11:35 |
Rep Power: 7 |
Thanks for the help.
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 05:53 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
SU2 config file solver settings (Dimensional vs freestream_press_eq_one) | jaiswal | SU2 | 2 | February 13, 2016 10:12 |
Compressible solver in SU2? | Vino | SU2 | 1 | November 26, 2014 20:02 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
