SU2 surface mesh update from EXTERNAL for steady state simulations help |
Hamid Attar
Rep Power: 7 ![]() |
For my masters final year project, I am running a 3D wing test case in SU2 and I am trying to supply new deformed surface coordinates for a deformed wing (due to pressure forces from flow passing over it). I have the .SU2 mesh file which contains the surface coordinates of a undeformed wing, which runs fine. I want to now replace the surface with the new deformed surface, and for it to calculate the locations of the new volume mesh, then perform the steady state simulation. I have set the following parameters in my .cfg file, but I am not sure if this is the correct thing to do as this is for dynamic mesh motion, where as I just want to update my mesh coordinates one time and then run the steady state simulation. % ----------------------- DYNAMIC MESH DEFINITION -----------------------------% % % Dynamic mesh simulation (NO, YES) GRID_MOVEMENT= YES % % Type of dynamic mesh (NONE, RIGID_MOTION, DEFORMING, ROTATING_FRAME, % MOVING_WALL, STEADY_TRANSLATION, FLUID_STRUCTURE, % AEROELASTIC, ELASTICITY, EXTERNAL, % AEROELASTIC_RIGID_MOTION, GUST) GRID_MOVEMENT_KIND= EXTERNAL Could someone please tell me how I can do this? Thanks! |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
