February 10, 2019, 04:46 |
SU2 Parallel Solution Restart Problem
akay bayat
Rep Power: 8 |
Hi everyone;
I have a problem about restart solution of SU2 in parallel mode. Firstly, i run my problem with 1000 iteration in parallel mode. Then i try to restart solution in parallel mode and program gave below error. su2_parallel_error.JPG If i choose serial mode, solution continues. Do you have any idea about this problm? |
June 22, 2019, 13:00 |
Hey!
I had the same error while doing unconstrained adjoint optimization of an airfoil. SU2_CFD somehow recognizes the end of the simulation (either convergence criteria with residual, cauchy or just iteration limit, I could reproduce the same behaviour) as an error and aborts and does not write the solution_flow.dat nor the restart_flow.dat, although in the logfile a nice convergence can be observed (at least in my case). The problem was, as I found after spending '"some" time on the problem, that I generated the mesh in Gmsh by fitting a spline on the contour points of the airfoil. Only lines about the contour then worked fine. The problem is very likely with the mesh or the way your mesh is defined. |
parallel solution, restart problem |
Problem with foam-extend 4.0 ggi parallel run | Metikurke | OpenFOAM Running, Solving & CFD | 1 | December 6, 2018 16:51 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
Ahmed body simulation gives unexpected results in su2 6.0 | anas651 | SU2 | 0 | March 28, 2018 04:42 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 12:58 |
Parallel interDyMFoam cellLevel problem | tgvosk | OpenFOAM Running, Solving & CFD | 5 | February 19, 2014 03:24 |
