January 31, 2019, 13:28 |
SU2 parallel optimization problem
Nikita Ageev
Rep Power: 9 |
Hello everybody!
I am trying to perform simple tutorial on optimization (inv_naca0012_basic.cfg) on Windows machine with precompiled binaries (v. 6.0.0). In serial mode it works well, but in parallel i've got some problems. The optimization starts, but only restart_flow.dat file is generated. It looks like SU2 _SOL.exe don't work (I don't know why, if I run it from DSN directory for config_SOL.cfd everything is OK). Where I can find the place in the script where SU2_SOL.exe is called? With version 5.0.0 everything is good with the optimization. Best regards |
February 1, 2019, 03:03 |
Solved
Nikita Ageev
Rep Power: 9 |
I solved this issue by replacing line 237 in the /SU2/SU2/run/interface.py from "the_Command = 'SU2_SOL ' + tempname" to "the_Command='SU2_SOL%s
%s' % (quote, tempname)" I will be glad if somebody helps me to post this on github. Update: the same thing with SU2_GEO. Last edited by n.d.ageev@gmail.com; February 1, 2019 at 04:09. |
February 2, 2019, 07:21 |
akay bayat
Rep Power: 8 |
In paralel mode, in order to decrease solution time program does not write flow.dat file. You can write solution file by using su2_sol.exe manually. |
February 2, 2019, 07:39 |
Nikita Ageev
Rep Power: 9 |
February 3, 2019, 10:07 |
akay bayat
Rep Power: 8 |
Oh sorry, i do not notice optimization. I have similar problem with you. After i solved a problem with 3000 iteration in parallel mode, program gives an error when i try to continue solution with restart file. If you find a solution, can you share with ne?
The problem when i use parallel computation for mesh deforming. | Hiroaki Sumikawa | OpenFOAM Running, Solving & CFD | 0 | November 20, 2018 03:58 |
Problem Building Parallel SU2 | StanislavKarpuk | SU2 | 4 | October 23, 2018 18:05 |
problem for parallel processing | minaret | OpenFOAM Running, Solving & CFD | 14 | January 20, 2015 00:41 |
SU2 Parallel - cannot access or exectute | dbaldzhiev | SU2 | 3 | November 24, 2014 18:02 |
problem about running parallel on cluster | killsecond | OpenFOAM Running, Solving & CFD | 3 | July 23, 2014 22:13 |
