Home > Forums > Software User Forums > SU2
Config file: "FREESTREAM_TURBULENCEINTENSITY" in % or ratio
Old   January 23, 2019, 06:40
Default Config file: "FREESTREAM_TURBULENCEINTENSITY" in % or ratio
j10
jayten
j10 is on a distinguished road
I am using the SST model in SU2 for computation of turbulent flow over a flat plate. The free-stream turbulence intensity of the fluid-flow I am computing is 3%. In the config.cfg file, whether I have to provide the free-stream value of turbulence intensity ("FREESTREAM_TURBULENCEINTENSITY") as 0.03 or 3.0?
j10 is offline   Reply With Quote
Old   July 22, 2019, 13:16
Vishal
raulvishal is on a distinguished road
If you check transition plate tutorial on SU2 website it shows 0.18% turbulent intensity to be entered as 0.18.
https://su2code.github.io/tutorials/...al_Flat_Plate/
But if you check the value of Turb. Kin. Energy when you run the simulation it will use 0.18 in following equation. (Turb. Kin. Energy = 3/2 (U I)^2). I feel considering I = 0.18% it should be entered as 0.0018.
It will be great if someone else can confirm about this confusion.
raulvishal is offline   Reply With Quote
Old   August 4, 2019, 07:02
Tim Albring
talbring is on a distinguished road
It is indeed like you are saying, 0.18% has to be entered as 0.0018. Thats a mistake in the tutorial case ...
Developer Director @ SU2 Foundation
Get involved:
talbring is offline   Reply With Quote
config files, turbulence intensity
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
