November 16, 2018, 07:46 |
Assigning Direction to flow
Akshay Malik
Rep Power: 10 |
Hi, I was doing simulation of flow over a missile, But the problem the direction of flow.
The missile was oriented in positive x direction, and the flow by default in SU2 is also oriented in positive x direction. I could not find any option, which can help me to change the flow direction to negative x. Although, there is one option FREE_STREAM_VELOCITY which takes 3 arguments, I tried giving -1 in first argument, but it was not helpful. If anyone has experience in dealing with this kind of situation, Please help. |
November 17, 2018, 12:16 |
Amit
Rep Power: 13 |
Angle of attack 180 deg may do the job but be careful with alpha and beta definitions (just check it out).
November 17, 2018, 12:34 |
Akshay Malik
Rep Power: 10 |
Thanks for reply.
Already tried AoA as 180, Not helpful. |
November 17, 2018, 12:46 |
Amit
Rep Power: 13 |
What happened?
November 17, 2018, 12:47 |
Akshay Malik
Rep Power: 10 |
The direction of flow did not change. There has to be some other way.
November 20, 2018, 00:28 |
C
Rep Power: 13 |
I have not experienced such a problem but maybe rotating the mesh using SU2_MSH may work.
November 20, 2018, 00:48 |
Akshay Malik
Rep Power: 10 |
Thanks, Rotating the mesh worked.
But, I just want to know for future, if there is some option to assign velocity direction. |
November 20, 2018, 00:57 |
Amit
Rep Power: 13 |
Angle of attack and sides slip angle option decides the flow velocity direction.......
December 12, 2019, 06:56 |
#9 |
Daniel
Rep Power: 7 |
How can I rotate the mesh using SU2_MSH?
su2 boundary condition, su2 configuration file, su2 error, su2 flow direction |
Question with flow direction | johnlui0302 | CFX | 1 | November 9, 2015 11:12 |
confusion in specifying domain flow direction and results | ashwani.thakur | CFX | 4 | February 28, 2015 06:45 |
High No Iterations in Secondary Flow Direction | camoesas | OpenFOAM Running, Solving & CFD | 0 | July 9, 2014 04:11 |
shear force and flow direction | ingear | Siemens | 0 | March 3, 2006 14:13 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
