Home > Forums > Software User Forums > SU2
Boundary layer profile extraction Tecplot
Old   November 15, 2018, 07:53
Exclamation Boundary layer profile extraction Tecplot
Bhupinder Singh Sanghera
Sanghera is on a distinguished road
Hi all,
I am currently post-processing the flow around a transonic turbine stator blade. I am trying to calculate the contributions of the different losses, such as the boundary layer loss, trailing edge loss and the shock loss.
For example, for the boundary layer loss I need the boundary layer properties just before the trailing edge. I have been trying hard the past days, but could not manage. The main problem that arises is that the blade profile is highly cambered and therefore extracting data along a straight line becomes a cumbersome task since this line must be perpendicular to the blade surface. This would require me to do some geometric calculations which introduces some possible errors. Since I have to do this for a matrix of designs, I am looking for a better and less error prone method. Please find attached the geometry. Any help is much appreciated!
https://imgur.com/a/CxlqvEj
Sanghera
Sanghera is offline   Reply With Quote
Old   May 19, 2020, 13:34
Cambridge is on a distinguished road
Hi
Have you got the answer? I need extract the profile as well.
Thank you
Cambridge is offline   Reply With Quote
Old   May 20, 2020, 05:18
Akshay Koodly
akoodlyr is on a distinguished road
I think the only way out here is to calculate the normals at different locations on the surface of your blade and extract the data from Paraview or Tecplot in batch mode. It could be somewhat error prone as mentioned, but I am not sure if there are any alternatives to automate it within SU2.
Cheers,
Akshay
akoodlyr is offline   Reply With Quote
boundary layer, su2, tecplot
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Any formula for approximating the boundary layer thickness around a cylinder? bestniaz Main CFD Forum 0 October 24, 2015 03:00
Validity & transformation of boundary layer equations Obad Main CFD Forum 2 April 27, 2015 03:59
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 14:47
