October 5, 2018, 11:00 |
su2 error when working large mesh size
anonymos
Rep Power: 16 |
SOLVED.
----------------------------------------------------------------- I have latest su2 version (falcon) for Windows10. I have solved many 3d problems without any problem so far. There is no problem when i study with grids of which grid size is less than 9 million. But, when i study with larger meshes, although i have more than enough memory, su2 stops working giving an error message (attached screen shot) during the partitioning process (Calling PerMETIS...) I got error message from limparmetis: Expression: sendind[i] >=firstvtx && sendind[i] <lastvtx I could not figure out what is the problem. I haven't tested it in linux environment and i dont know this error happens on windows only or not. But it is obvious there is some problem with parallel partitioning. Please help and advise. Thank you error.png Last edited by erkut; October 14, 2018 at 05:08. Reason: solved.. |
large mesh, parallel, su2 |
DPM simulation-Restrictions on the mesh size to particle size ratio? | cryabroad | Fluent Multiphase | 5 | June 16, 2022 01:51 |
Salome cgns format mesh to SU2 | JPBLourenco | SU2 | 19 | November 18, 2019 02:11 |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 09:29 |
Gmsh mesh to SU2 error : "corrupted size vs. prev_size" | Cmac22 | SU2 | 10 | August 9, 2017 12:19 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
