August 18, 2018, 21:41 |
why there is no velocity value in flow.vtk?
cean wang
Rep Power: 13 |
hi,
i have done a few simulations and like to draw the velocity vector on a plane. but can't find any velocity value in flow.vtk. where should i look at? regards, cean |
August 20, 2018, 05:38 |
Pedro Gomes
Rep Power: 13 |
SU2 outputs the momentum (depending on version it may also be called conservative_"some number") if you divide that by density you get velocity.
August 26, 2018, 00:28 |
cean wang
Rep Power: 13 |
I tried to plot momentum directly.
I' ll figure out if i save velocity directly or compute from momentum. thx. |
October 1, 2018, 14:30 |
Amit
Rep Power: 13 |
In ParaView, you have calculator. Here you can divide conservative2 or 3 or 4 (momentum x or y or z) by conservative1 (density) to obtain the velocity components in x, y and z direction.
serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 08:56 |
wrong velocity contour of rotating propeller - Fluent | calv | FLUENT | 1 | September 6, 2018 11:48 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
