August 15, 2018, 05:12 |
What is the unit of dimensional force?
cean wang
Rep Power: 13 |
In Forces_breakdown.dat I get: Forces breakdown: Center of Pressure: X=0.426311Z+5399.999366 m. NOTE: Multiply forces by the non-dimensional factor: 50000000.000000, and the reference factor: 1418.550000 to obtain the dimensional force. Total CL: 0.707787 | Pressure ( 99%): 0.707787 | Friction ( 0%): 0.000000 | Momentum ( 0%): 0.000000 Total CD: 0.301737 | Pressure ( 99%): 0.301737 | Friction ( 0%): 0.000000 | Momentum ( 0%): 0.000000 Total CSF: -0.000952 | Pressure ( 100%): -0.000952 | Friction ( 0%): 0.000000 | Momentum ( 0%): 0.000000 Take Drag as example: Drag= 0.301737 * 50000000.000000 * 1418.550000 What's the unit of it? N,kN? Thanks for help. Regards, Cean |
August 15, 2018, 05:56 |
Pedro Gomes
Rep Power: 13 |
If you use SU2 in SI units the force is in Newton.
August 15, 2018, 08:43 |
cean wang
Rep Power: 13 |
thank you very much.
after using the correct unit, even the incomp caculation can reach convergence. |
udf for one dimensional linear motion based on force | maccheese | Fluent UDF and Scheme Programming | 2 | September 1, 2019 02:18 |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 11:12 |
Calculation of Drag Force per unit Length | Mohammad Faridul Alam | CFX | 4 | January 11, 2013 07:19 |
what the unit of the results got from force function | lilinghan8 | OpenFOAM | 1 | June 11, 2012 09:07 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
