Home > Forums > Software User Forums > SU2
SU2 python scipt runs in parallel but repeats the simulation
Old   August 10, 2018, 19:42
Default SU2 python scipt runs in parallel but repeats the simulation
topheruk
topheruk29 is on a distinguished road
If I use the python library to call SU2 and run in parallel, the simulation runs to completion but then repeats the simulation x-number of times, where I think x is equal to the number of processors. Also the run times reported are for the number of processors specified. The issue can be repeated with the following python script:
config = SU2.io.Config(filename)
config.NUMBER_PART = 4 # 0 for serial
config.NZONES = 1
SU2.run.CFD(config)
However, the simulation works in parallel as expected if I use the terminal commands:
mpirun -n 4 SU2_CFD filename.cfg
Any ideas?
*UPDATE1*: issue partly resolved, the parallel_computation.py scipt in the SU2_PY directory ran the simulation in parallel without repeating. Still not sure why the above python script does not work, however.
*UPDATE2*: issue fully resolved, I was calling SU2.eval.func('DRAG', config), SU2.eval.func('LIFT', config), and SU2.eval.func('MOMENT', config) in addition to SU2.run.CFD(config)
topheruk29 is offline   Reply With Quote
Old   August 13, 2018, 19:01
hlk
Heather Kline
hlk is on a distinguished road
Hello
Thanks for your interest in SU2
I'm glad to hear you got your problem working.
hlk is offline   Reply With Quote
mpi, parallel, python, su2
Installing SU2 v5 for Parallel Computations McAero SU2 Installation 4 December 10, 2017 18:02
First Step Parallel Simulation and HPC FlyBob91 OpenFOAM Running, Solving & CFD 3 July 14, 2017 10:05
Executing simulation in parallel. orte_init failed vidyadhar OpenFOAM Running, Solving & CFD 2 June 30, 2017 01:13
Python for postprocessing output of SU2 juanbaus SU2 2 May 2, 2017 00:59
SU2 parallel installation error JAlbert SU2 Installation 2 November 19, 2013 03:43
