Home > Forums > Software User Forums > SU2
Errors when running Shape Optimization Tutorial 1 - NACA0012
Old   August 9, 2018, 00:25
Default Errors when running Shape Optimization Tutorial 1 - NACA0012
David
northfly is on a distinguished road
I tried running the shape optimization tutorial 1: Unconstrained shape design of a transonic inviscid airfoil at a cte. AoA using the given cfg and mesh file. But it seems the process only goes for 4 steps and stop. No matter I use python2 or python3, it is the same. What could cause the problem here? Thank you very much!
when using python2:
  NIT    FC           OBJFUN            GNORM
    1     1     2.946447E-08     6.646259E-06
    2     3     2.927194E-08     5.513828E-06
    3     4     2.037004E-08     4.516896E-06
    4     6     1.769283E-08     5.893302E-06
Traceback (most recent call last):
  File "/opt/SU2/SU2-6.0.0/build/bin/shape_optimization.py", line 187, in <module>
    main()
  File "/opt/SU2/SU2-6.0.0/build/bin/shape_optimization.py", line 118, in main
    options.nzones      )
  File "/opt/SU2/SU2-6.0.0/build/bin/shape_optimization.py", line 163, in shape_optimization
    SU2.opt.SLSQP(project,x0,xb,its,accu)
  File "/opt/SU2/SU2-6.0.0/build/bin/SU2/opt/scipy_tools.py", line 143, in scipy_slsqp
    epsilon        = eps            )
  File "/usr/lib/python2.7/dist-packages/scipy/optimize/slsqp.py", line 207, in fmin_slsqp
    constraints=cons, **opts)
  File "/usr/lib/python2.7/dist-packages/scipy/optimize/slsqp.py", line 370, in _minimize_slsqp
    raise ValueError("Objective function must return a scalar")
ValueError: Objective function must return a scalar
when using python3:
  File "/usr/lib/python3.6/shutil.py", line 544, in move
    os.rename(src, real_dst)
FileNotFoundError: [Errno 2] No such file or directory: '/home/xu/TutorialSU2/Unconstrained_Airfoil_Design_NACA0012_AOA/DESIGNS/DSN_006/DIRECT/solution_flow.dat' -> '/home/xu/TutorialSU2/Unconstrained_Shape_Design_of_a_Transonic_Inviscid_Airfoil_at_an_AOA/DESIGNS/DSN_006/solution_flow.dat'
During handling of the above exception, another exception occurred:
  File "/opt/SU2/SU2-6.0.0/build/bin/SU2/eval/design.py", line 146, in _eval
    vals = eval_func(*inputs)
  File "/opt/SU2/SU2-6.0.0/build/bin/SU2/eval/design.py", line 243, in obj_f
    func += su2func(this_obj,config,state) * sign * scale * global_factor
  File "/opt/SU2/SU2-6.0.0/build/bin/SU2/eval/functions.py", line 98, in function
    aerodynamics( config, state )
  File "/opt/SU2/SU2-6.0.0/build/bin/SU2/eval/functions.py", line 273, in aerodynamics
    push.append(info.FILES['TARGET_HEATFLUX'])
  File "/opt/SU2/SU2-6.0.0/build/bin/SU2/io/redirect.py", line 250, in __exit__
    shutil.move(old_name,new_name)
  File "/usr/lib/python3.6/shutil.py", line 558, in move
    copy_function(src, real_dst)
  File "/usr/lib/python3.6/shutil.py", line 257, in copy2
    copyfile(src, dst, follow_symlinks=follow_symlinks)
  File "/usr/lib/python3.6/shutil.py", line 121, in copyfile
    with open(dst, 'wb') as fdst:
FileNotFoundError: [Errno 2] No such file or directory: '/home/xu/TutorialSU2/Unconstrained_Shape_Design_of_a_Transonic_Inviscid_Airfoil_at_an_AOA/DESIGNS/DSN_006/solution_flow.dat'
  File "/usr/lib/python3/dist-packages/scipy/optimize/slsqp.py", line 368, in _minimize_slsqp
    fx = float(np.asarray(func(x)))
  File "/usr/lib/python3/dist-packages/scipy/optimize/optimize.py", line 292, in function_wrapper
    return function(*(wrapper_args + args))
  File "/opt/SU2/SU2-6.0.0/build/bin/SU2/opt/scipy_tools.py", line 393, in obj_f
    obj_list = project.obj_f(x)
  File "/opt/SU2/SU2-6.0.0/build/bin/SU2/opt/project.py", line 236, in obj_f
    return self._eval(konfig, func,dvs)
  File "/opt/SU2/SU2-6.0.0/build/bin/SU2/opt/project.py", line 205, in _eval
    vals = design._eval(func,*args)
  File "/opt/SU2/SU2-6.0.0/build/bin/SU2/eval/design.py", line 150, in _eval
    save_data(filename,self)
  File "/opt/SU2/SU2-6.0.0/build/bin/SU2/io/redirect.py", line 253, in __exit__
    os.chdir(origin)
FileNotFoundError: [Errno 2] No such file or directory: '/home/xu/TutorialSU2/Unconstrained_Shape_Design_of_a_Transonic_Inviscid_Airfoil_at_an_AOA/'
    main()
    options.nzones      )
    epsilon        = eps            )
  File "/usr/lib/python3/dist-packages/scipy/optimize/slsqp.py", line 207, in fmin_slsqp
  File "/usr/lib/python3/dist-packages/scipy/optimize/slsqp.py", line 370, in _minimize_slsqp
northfly is offline   Reply With Quote
Old   August 13, 2018, 06:33
pcg
Pedro Gomes
pcg is on a distinguished road
The optimizer may have deformed the mesh too much and the solver diverged.
Have a look inside the optimization project directories and see what the mesh looks like at the last iteration.
I experienced the same problem before and adding a constraint on pitching moment helped, the shapes were more reasonable.
Regards,
Pedro
pcg is offline   Reply With Quote
Old   August 13, 2018, 18:59
hlk
Heather Kline
hlk is on a distinguished road
Hello
Thank you for your interest in SU2
Are you using the most recent version of SU2 (it would be 6.1.0 by the date of your post)? Are you also using the most recent configuration, mesh, and solution files as provided with that SU2 version or from https://su2code.github.io/, without modification?
If yes, please report this as an issue at https://github.com/su2code/SU2/issues, and feel free to reference your original post as well as pcg's suggestion which sounds like it fixed the problem.
Thanks for using the forum! It's exactly the right place to go to get help with using SU2, and we usually encourage people to take their questions here first where a wider audience of people can help out - but the tutorials are supposed to work without requiring the user to make any modifications, and if it's broken that's something that should be fixed on the developer end, which is what the 'issues' tab in github is for.
hlk is offline   Reply With Quote
Old   August 15, 2018, 05:09
David
Thanks, PCG and HLK for your help.
It is using the newest version of code and configuration file. I already submitted the issue to the link you provided.
I would try PCG's method and try more.
HLK:
You sounds like the code contributor/senior developer of SU2. Is it possible we write more detailed document and publish it so that more people can join in using it and starting to develop it. I could offer my labor effort, but I don't know where to start. Reading the code alone is hard.
Old   August 15, 2018, 07:17
pcg
Pedro Gomes
Hi northfly,
The papers (https://github.com/su2code/Documentation) can give you an idea of the major software components of the SU2 suite and the major classes in SU2_CFD.
The doxygen documentation can help you understand the variety of sub-classes you have for each of the major ones.
Reaching out directly to the person/group that developed a feature is also one way to get some help (used to be the main one I've been told).
Anyway, If you want to fix a bug yourself and need some pointers using the GitHub issues is probably the best way. If you want to develop a new feature I recommend that you register to the developer society (https://www.su2devsociety.org/) and start a thread (the society is relatively new so not much movement in the forum yet).
Regards,
Pedro
Old   January 30, 2019, 14:38
Nikita Ageev
n.d.ageev@gmail.com is on a distinguished road
I have the same problem with tutorial (at SU2 v 6.1.0). At the same node the SU2 v 5.0.0. wirks correctly with the same tutorial.
Are there any news on these issues?
Best regards
n.d.ageev@gmail.com is offline   Reply With Quote
Old   February 14, 2019, 04:35
atelcikti1's Avatar
atelcikti1 is on a distinguished road
Any solution to this problem? I'm also working on 6.1 version.
atelcikti1 is offline   Reply With Quote
Old   February 14, 2019, 04:46
Nikita Ageev
SU2 parallel optimization problem
Here some steps that helped me.
Error problem while running sadia d lts tutorial kane OpenFOAM Running, Solving & CFD 2 May 26, 2018 04:38
Segmentation fault in tutorial NACA0012 shape optimization lazzini SU2 Shape Design 3 March 16, 2018 05:41
Problem with running tutorial "Constrained Optimal Shape Design of a Fixed Wing" yugang881 SU2 12 February 3, 2017 08:15
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
