Home > Forums > Software User Forums > SU2
SU2 code scaling poorly on multiple nodes
View Poll Results: Does SU2 scales well on multiple nodes?
Yes 0 0%
No 0 0%
Dont know 0 0%
Voters: 0. You may not vote on this poll
Old   July 18, 2018, 06:22
Default SU2 code scaling poorly on multiple nodes
Samir Shaikh
Samirs is on a distinguished road
Hi All,
I have successfully compiled parallel version of SU2 on our HPC cluster having Intel Broadwell nodes. I made changes in parallel_computation.py so as to make mpirun command for running SU2_CFD in parallel. On single node I can see a linear scaling with number of mpi processes but when executing same script through batch mode using SLURM on multiple nodes, performance is degrades.
I tried simulation of Turbulent ONERA_M6 testcase.
Thanks in advance for your suggestions / help in this regard
Attached is slurm script to submit job
File Type: txt slurm_script_su2.txt (667 Bytes, 16 views)
Samirs is offline   Reply With Quote
Old   August 25, 2018, 20:15
hlk
Heather Kline
hlk is on a distinguished road
You may want to refer to SU2_PY/SU2/run/interface.py to see how the mpi command is called from the python scripts, to make sure that this works with your cluster. You can also set the SU2_MPI_COMMAND in your config file to set something customized without needing to modify the python scripts.
Sometimes multiple nodes each with several processors scales worse than multiple processors within a single node because information now has to travel between multiple nodes rather than just within a single node - and, what sometimes surprises people, is that it actually matters how long the cable is that connects the nodes. However, on most modern clusters it shouldn't be so extreme as to prevent you from benefiting from multiple nodes. If it is an extreme difference you can try running other parallel programs that require communication between processes, or contacting your system administrators about what they expect for the difference in communication between vs within nodes, and tips on compiling in a way to optimize for the specific cluster architecture.
Originally Posted by Samirs View Post
Hi All,
hlk is offline   Reply With Quote
intel broadwell, intel compiler, su2 aerodynamic noise, su2 examples
Autogrid export CGNS mesh only with multiple base nodes??? swm Fidelity CFD 5 January 22, 2017 03:09
multiple zone CGNS file convert to su2? jywang SU2 2 June 20, 2016 06:29
pimpleDyMFoam on multiple nodes amd OpenFOAM Running, Solving & CFD 0 October 9, 2012 05:59
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 16:56
Open source CFD code development, possible? Dr. Yazid Bindar Main CFD Forum 27 July 18, 2000 01:18
