Home > Forums > Software User Forums > SU2
CGNS Reader cannot handle more than 1 zone?
Old   July 12, 2018, 00:57
Default CGNS Reader cannot handle more than 1 zone?
David
northfly is on a distinguished road
I output CGNS file from ICEM-CFD with 3.1ADF option. The mesh is airfoil with multi-block conversion.
but looks like SU2 cannot handle, if zone number is limited to 1, then SU2 is almost useless.
Can anybody tell me how can I output mesh from ICEM-CFD to SU2? what format and what procedures? Thank you very much!
northfly is offline   Reply With Quote
Old   July 12, 2018, 10:24
David
I am guessing SU2 is a unstructured solver, so I need convert the mesh to unstructured form and then output to CGNS, and some lower version say 2.4 CGNS. Is this so?
Old   July 17, 2018, 06:47
na
TKatt is on a distinguished road
as you said the you have to convert the mesh to an unstructured mesh (SU2 = Stanford University Unstructured ). I use CGNS 3.1 ADF as export from ICEM and didn't have any problems so far. You can either use the .cgns mesh directly in SU2 or convert the mesh to the native .su2 format (see https://su2code.github.io/tutorials/Inviscid_Wedge/). Note though, that the mesh for the solver has to be in meters [m].
Regards, Tobi
TKatt is offline   Reply With Quote
Old   July 25, 2018, 09:58
David
Thank you very much Tkatt!
Old   July 26, 2018, 22:10
David
Originally Posted by TKatt View Post
Regards, Tobi
When you use ICEM t0o output, how do you set those options?
Create default BC patches? Yes/No?
Entities to use for BC patch? Face Elements/Nodes?
Create Bar and node elements? Yes/No?
Thanks!
Old   August 30, 2018, 04:42
na
I stick with the (default) options: [No | Nodes | No].
In order to adress the boundaries through the cfg file I create named "Parts" in ICEM.
Sorry for the late reply, I didn't notice your followup question.
Regards Tobi
Old   April 24, 2024, 05:11
Tomas Perez Zapico
tomaspzapico is on a distinguished road
I al having problems using both the .cgns mesh and the converter embedded into SU2. My mesh is a multi-zone mesh and whenever I try to run the SU2_DEF or the SU2_CFD with the multizone option activated, the following message appears:"CGNS reader currently expects only 1 zone per CGNS file.Multizone problems can be run with separate CGNS files for each zone."
Does anybody know how can I fix this problem?
tomaspzapico is offline   Reply With Quote
Old   April 25, 2024, 17:00
bigfoot
bigfootedrockmidget is on a distinguished road
I think you just have to split the cgns into separate cgns files for each zone.
bigfootedrockmidget is offline   Reply With Quote
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 12:25
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
