Cannot extract surfaces of the .vtk file in Paraview |
June 3, 2018, 04:37 |
Chris
Rep Power: 9 |
I´m facing the problem that the generated .vtk file from SU2 to analyze the results of my simulation in PARAVIEW does not allow me to extract spezific faces of my simulation. I'm simulating a wing and I gave the upper and the lower side of the wing different markers in the .cfg file. In PARAVIEW I just want to see the results of the upper side. But the buttons for the appropriate surface or block extraction filters are greyed out. So I am just able to see the solution of the whole domain. Does anybody know a solution of my problem? Do I have to pay attention to something special loading in the .vtk file? Kind regards |
July 2, 2018, 12:11 |
Amit
Rep Power: 13 |
Surface markers will be written to surface_flow.vtk u can load this in ParaView and visualize
July 2, 2018, 12:43 |
Chris
Rep Power: 9 |
Thanks,
When I open the surface_flow.vtk with notepad++ i cannot see anything that would give PARAVIEW a clue where to find the different marker_surfaces. I´m currently genereting the mesh in a different software (ANSA) and export it to CGNS. Do you use also CGNS and can see the different marker_faces? |
July 2, 2018, 21:31 |
Amit
Rep Power: 13 |
Different marker faces...
It exports all the faces u specify to export as a single entity (In PARAVIEW) . You can also specify individual faces u want to analyze in MARKER Plotting and rerun it multiple times to get output for different faces and save them with different names (a workaround). Last edited by aero_amit; July 12, 2018 at 11:01. |
August 15, 2018, 09:46 |
cean wang
Rep Power: 13 |
i also want a function to write surface data.to individual file for each marker.
paraview, su2 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 17:25 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
