Home > Forums > Software User Forums > SU2
Can SU2_v6.0 simulate the rotor - stator problem?
Old   May 19, 2018, 07:04
Question Can SU2_v6.0 simulate the rotor - stator problem?
hust
zjqzjs is on a distinguished road
Hi everyone,
The sliding mesh capabilities allowing for multiple zones in relative motion can be used in version 6.0.0? I want to simulate a 2D rator-stator problem. I have tried examples of sliding mesh in testcases. However, there is no .cfg file applicable to this problem. Any suggestions?
btw, I have two questions:
1. How to use adaptive mesh method in SU2? In SU2_6.0.0, there is a function of GRID ADAPTATION STRATEGY. However, there is not example explain how to use it. I have tried many times, no mesh adaptive happened when add this part in my .cfg file.
2. How to run the examples of turbomachinery? For example, I use the command SU2_CFD Axial_stage2D.cfg to run the case of axial_stage_2D, the error is as follows,
---------------------- Python Interface Preprocessing ---------------------
Setting customized boundary conditions for zone 0
Setting customized boundary conditions for zone 1
------------------------------ Begin Solver -----------------------------
nan in mixing process routine for iSpan: 0 in marker inflow
nan in mixing process routine for iSpan: 1 in marker inflow
nan in mixing process routine for iSpan: 0 in marker outmix
nan in mixing process routine for iSpan: 1 in marker outmix
nan in mixing process routine for iSpan: 0 in marker inmix
nan in mixing process routine for iSpan: 1 in marker inmix
nan in mixing process routine for iSpan: 0 in marker outflow
nan in mixing process routine for iSpan: 1 in marker outflow
Error in "void CSysSolve::ModGramSchmidt(int, std::vector<std::vector<double> >&, std::vector<CSysVector>&)":
SU2 has diverged.
------------------------------ Error Exit -------------------------------
If so any examples setting such problems would be a real help.
Thanks.
zjqzjs is offline   Reply With Quote
a case which is very tough to simulate....... sharonyue OpenFOAM Running, Solving & CFD 6 November 22, 2012 02:20
Simulate the wind profile on a wind turbine---> HOW ???? mohammad Main CFD Forum 0 April 13, 2012 09:16
Simulate the wind profile on a wind turbine---> HOW ???? mohammad Main CFD Forum 0 April 13, 2012 09:07
Please help me to simulate a river using CFD-ACE+ Sas Main CFD Forum 0 August 27, 2002 21:51
What is best way to simulate big particle yueroo FLUENT 2 April 13, 2001 22:28
