May 11, 2018, 03:13 |
SU2 Parallel - Mpirun Error
Ankara
Hello, I have done the SU2 parallel build. I was able to run parallel with this command "mpirun -n 64 SU2_CFD turb.cfg . However, now I got this error message "63 more processes have sent help message help-mpi-btl-base.txt". It runs too slow. How can I fix it?
May 14, 2018, 18:02 |
Too Many Processes?
Peter Brady
Rep Power: 12 |
I'm not sure about the error message but is 64 processes too much? I usually try to run a few short tests on lower core counts to get a handle run times and how my job is going to scale out. Then I'll decide the final core count I want to run on and kick the production run off. I've found that scale out is a balance between cells per core and communication so simply shoving huge core counts at a problem may not always be the best. A quick google of the error text indicates that it may not be a problem and is a warning. Are you running on a local machine or across a network? See: https://github.com/open-mpi/ompi/blo...i-btl-base.txt |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 07:45 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 19:44 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 13:34 |
